Where to buy outrunner cooling fan? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 11-07-2009, 08:07 PM
DKNguyen
Default Where to buy outrunner cooling fan?
Does anyone know where to begins searching for centrifugal or axial cooling fans for outrunners? Google doesn't seem to turn up much except for motors that already come with cooling fans.
I'm searching for a fan for a Hyperion ZS3025 similar to the attached photo.
DKNguyen is offline
Old 11-08-2009, 05:22 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
If they are available, one of these places will have it.
US distributer = http://www.allerc.com/
World wide = http://www.aircraft-world.com/
Larry3215 is offline
Old 11-10-2009, 06:58 PM
43851E
Pulso Dealer
43851E's Avatar
Default Pulso Cooler
I am a dealer for Pulso, however I currently do not have any. Have a look at the link below. You can also find then on my website. You can look at what motor serries they fit & see if that is the same as your Hyperion ZS3025. If you have difficulty with the fit let me know & I will be glad to recommend one.
http://www.pulsosystem.com/motor/cooler.html
Good luck & stay cool!
Doug
43851E is offline
Old 11-10-2009, 11:32 PM
DKNguyen
Bah! So close! Down to the three screw mount. But it appears that the PUlso cooling fans have sloped fins to mesh perfectly with the sloped rear of the can. THe Hyperion can is flat.
DKNguyen is offline
Old 11-11-2009, 02:04 AM
43851E
Pulso Dealer
43851E's Avatar
DKNguyen,
I did a quick search on your Hyperion ZS3025, never found the shaft size. Is it a 5mm or 4mm? Sharp eyes you have, yes the blades are tapered. Down to the three screw mount. Almost exact, but improved.
Let me inquire with the factory what the current status of these are. Good thing with these is, all the small parts are extreamly affordable from Pulso. I give them away for free included with every motor; "X" & Radial mounts.
The fans were just coming before I ordered. Depending on your timeline, something could be arranged. Let me know.
Take care,
Doug
43851E is offline
Old 11-11-2009, 05:34 PM
DKNguyen
The shaft is 5mm. I don't have a timeline really. Not in a rush for anything. I don't think the fans can be tapered though. They're tapered to make a nice seal around the sloped rear of the Pulso cans. The Hyperions don't have that so it would have large gaps between the case and fan blades.
DKNguyen is offline
Old 11-12-2009, 05:23 AM
43851E
Pulso Dealer
43851E's Avatar
Well looks like those won't work with the Hyperion. Larry1325 had some links. Hope those will work out for you! It's times like this that I like to head over to the mill & lathe and make my own!
Sorry I could not help out with that fan. Well good luck & take care.
43851E is offline
Old 11-22-2009, 08:02 PM
peterangus
I have made several centrifugal cooling fans for outrunners, using hand-tools only.
Material used was .010" aluminium. [.010" tinplate would be OK]
They work well, and can be made in about 15 minutes.
peterangus is offline
Jarsalla
13
09-15-2009 05:21 AM
Gohmer
02-08-2009 08:48 PM
FinnFlyer
Electric Ducted Fan Jets
19
09-21-2007 02:34 AM
Joe 1320
12-28-2006 03:49 PM
LDM
01-03-2006 08:59 PM
Quick Reply: Where to buy outrunner cooling fan?
Page generated in 0.08800 seconds with 11 queries
