some more Prop adaptor help.. "PLEASE Ignore" - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Electronic Builders Workshop Discuss how to build motors, ESC's, chargers, mixers, etc here
Old 11-18-2009, 08:26 PM
Fulanito_uk
Default some more Prop adaptor help.. "PLEASE Ignore"
SOLVED!
Hello all,
After looking more carefully on my motor i find out it has a prop adaptor already installed!!!
now how the hell do i unscrew it? its like a chinese puzzel and i don't want to damage the motor or shaft?
i have exactly this set up (except its all screwed in) with a prop i dont want sandwhiched in the middle?!
Thanks for the help.. i have a feeling as i start my build i'm going to need lots more of it!
Fulanito_uk is offline
Old 11-19-2009, 12:16 AM
Bub Steve
Bub Steve's Avatar
Stick a small screw diver though the small hole on the front and hold the round part behind it then turn to unscrew, it clamps down on the shaft by compression and will release when you unscrew the front hub,,, bubsteve
Bub Steve is offline
Old 11-19-2009, 08:01 PM
Terry.0132
I agree with stevecooper, I sometimes find it helps to hold on to the base of the prop adaptor with a long nosed pliars. If you then have the spinner and prop off but the base of the adator does not want to come loose I use a broad screwdriver to release the cover from the collet. Hope it works
Terry.0132 is offline
Old 11-19-2009, 08:37 PM
Fulanito_uk
of course! all your tips are welcome! (and i'll need a lot more as i start my first ARTF e flite cub!!)
Old 11-20-2009, 12:13 AM
Bub Steve
Bub Steve's Avatar
She's a sweet-heart,, you'll love her, bubsteve
Old 11-29-2009, 03:47 PM
43851E
Pulso Dealer
43851E's Avatar
Hello Fulanito -
Be sure to put some sort of lubricant on those threads that is thick, lots of solids. I like the plumber's teflon (not tape) crayon. Nothing works better. Never mind the purple thing...
Blue Skies, Doug
43851E is offline
Tim
9
10-07-2009 10:45 PM
Borabora22
08-12-2009 10:04 PM
skylane42
Batteries & Chargers
10
08-25-2008 04:59 PM
Old Fart
10
06-19-2007 01:39 AM
rcmark
05-11-2007 12:55 AM
Quick Reply: some more Prop adaptor help.. "PLEASE Ignore"
Page generated in 0.06041 seconds with 15 queries
