Problems with motor/ESC/radio setup? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 03-12-2006, 05:28 PM
rccliff
Default Problems with motor/ESC/radio setup?
I'm new to electric flight and I have a problem!
I just purchased a Electrify SS-12 speed control & Rimfire motor. I hooked up everything according to directions, motor spins in correct direction, but throttle stick is reversed (on Futaba FGK transmitter). That is, the motor is off when the throttle stick is UP. How do I reverse this?
When I reverse the transmitter switch for throttle direction, the motor doesn't operate (continuous beeps).
Please help!
Cliff Bowman
rccliff is offline
Old 03-13-2006, 01:22 PM
giflyrc
Gravity is Attractive
The solution may be as easy as setting the throttle trim to it's lowest position, then power up your esc with the throttle stick all the way down
If that don't work, reverse the channel switch again
Keep in mind that the ESC needs to initialize to full low throttle, full low trim.
Roger aka GIFLYRC
giflyrc is offline
bert269
02-11-2010 04:55 AM
Evan
03-02-2008 04:16 AM
peterkron
03-03-2007 05:01 AM
lennyshotgun
28
06-24-2006 10:54 AM
wilscor41
22
02-05-2006 02:41 PM
Quick Reply: Problems with motor/ESC/radio setup?
Page generated in 0.05003 seconds with 13 queries
