slow v rebuild - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
slow v rebuild
Old 08-07-2010, 06:42 PM
kargo
Default slow v rebuild
Hey gang, I'm replacing the stock motor and esc on my slow v with a towerpro motor/esc package. I can't seem to figure out how to make the mount that came with this motor work out, has anyone replaced the motor on their slow v and what mount did you use?
kargo is offline
Old 08-07-2010, 06:53 PM
philipa_240sx
Yup, I did exactly the same to my plane. You need to use the supplied stick mount, cut it down, and shim it with some balsa or thin ply to fit the Slo-V's smaller 8mm stick. I would recommend drilling through the side of the mount and into the fuse, then installing either a small screw or nut & bolt to secure it.
Name:	Slo-V Stick mount - Back.JPG
ID:	133271   Click image for larger version
Name:	Slo-V Stick mount - Front.JPG
ID:	133272   Click image for larger version
Name:	Slo-V Stick mount - Side.JPG
ID:	133273   Click image for larger version
philipa_240sx is offline
Old 08-07-2010, 07:00 PM
philipa_240sx
With more than double the stock power, the TP2410 really makes the Slo-V enjoyable to fly... it's addictive!
Just be forewarned:
1) The Slo-V has a very draggy fuse. This was at least part of the cause of rear bearing failures I experienced on the TP2410. I went through 3 sets of rear bearings in a year. You can find replacements here:
http://www.headsuprc.com/servlet/the...--3mm-x/Detail
2) Use a prop saver. The TP2410 shaft is easily bent.
http://www.headsuprc.com/servlet/the...r-3.0mm/Detail
3) Keep an eye on the fuse. I started to experience cracking of the CF. This could be due to stresses from motor torque, crashes, etc. Eventually I had to retire the plane because of it.
Old 08-07-2010, 07:24 PM
Bub Steve
Bub Steve's Avatar
You can make the slow vee into a GREAT PLANE with a arrow shaft and some chuck-Glider wing's out of the stock set-up you'll have left-over SlowVee, bubsteve, PS there's a thread i did years ago on it, I'll look for it if you'd like,
ID:	133284   Click image for larger version
ID:	133286   Click image for larger version
ID:	133287   Click image for larger version
ID:	133288   Click image for larger version
Bub Steve is offline
Old 08-07-2010, 10:14 PM
kargo
Default thanks!
thanks for the replys gang, i'll mod the stock mount the way philipa did!
kargo is offline
Old 08-07-2010, 11:17 PM
philipa_240sx
I actually miss my Slo-V... she was fun to fly once I reworked her. The only thing left was the fuse:
- Motor: TP 2410-09Y motor, 20A Power Up ESC, and prop saver from HeadsUpRC
- Prop: Parkzone 11x4.7
- 1250 mAh 3S Lipo
- Spektrum AR500 RX
- 2x SG90 servos
- KFM3 42" wing
- 3mm depron tail feathers reinforced with bamboo skewers.
- LG: E-Flite 2.5" wheels, stock PZ tail skid
- AUW: 17oz
Old 08-07-2010, 11:19 PM
philipa_240sx
There is a good 'How-To' on using the stick mount here:
http://www.wattflyer.com/forums/showthread.php?t=31473
Old 08-07-2010, 11:56 PM
philipa_240sx
Kargo, check your PM
I have some spare parts for the Slo-V including my modified motor mount if you want them.
baz49exe
Warbird Electrics
118
05-13-2009 07:27 PM
thehaze
Warbird Electrics
05-09-2008 03:58 AM
wecky
Foamies
01-02-2007 04:42 AM
jim
08-03-2006 05:19 PM
pappy60
Electronic Builders Workshop
08-11-2005 02:01 PM
Quick Reply: slow v rebuild
Page generated in 0.09617 seconds with 23 queries
