V tail setup
Old 08-07-2010, 06:53 PM
kargo
Default V tail setup
Hey gang,
Trying to change out the stock equipment on my slow v. Since I'm changing the reciever out I need to set up a v tail mix on my radio. My question is which direction should the control surfaces move? You'd think I'd have checked this out with the stock equipment in it first huh
My radio is a Futabe 6EX, programing seems straight forward so once I figure out which direction things ought to go it should work great.
kargo is offline
Old 08-07-2010, 11:25 PM
philipa_240sx
Control surface movements are described on Pg 6 of the Slo-V manual if you still have it:
http://www.horizonhobby.com/ProdInfo...300-manual.pdf
Here is the specific page:
Name:	Slo-V Manual.jpg
philipa_240sx is offline
Old 08-07-2010, 11:35 PM
philipa_240sx
Since the Slo-V is a 3 channel plane, you are actually looking for elevon or delta wing mixing. This keeps the primary flight controls on the right stick... aileron and elevator.
V-tail mixing on the other hand uses elevator and rudder. Much harder to fly IMHO.
Old 08-08-2010, 12:44 AM
flydiver
flydiver's Avatar
As philipa says-don't use V-tail, use elevon or delta-which ever the Futaba offers.
That drove me crazy for hours trying to set it up.
V-tail setting is for like a sailplane with a V-tail and ailerons.
flydiver is offline
Old 08-08-2010, 02:57 AM
philipa_240sx
Yeah, it's tricky to setup the V-tail. If you don't get the desired tail movement, try the following:
1) Swap the servo wires/channels
2) Use the servo reversing feature of your radio to change direction of the offending servo.
Old 08-08-2010, 04:47 AM
kargo
Default thx
Thanks gang, that helps a lot. Geez the manual sure was an obvious place to look thanks for pointing it out, and the pointers. Soon as I deal with the mounting issues of my towerpro motor I'll be able to give it a try...
kargo is offline
Old 08-22-2010, 10:17 PM
RTFM - Read the friendly manual. Always worth a try.
AEAJR is offline
Old 08-23-2010, 03:58 AM
philipa_240sx
I posted in your other thread about motor mounting. It's really quite simple.
Good luck!
wzak29
11-16-2009 11:19 AM
GreenAce92
Aerodynamics
03-08-2009 07:14 AM
restlessworker
E-Flite Helicopters
22
02-19-2009 03:18 AM
n2Jesus
11-26-2007 02:09 AM
photors
10-04-2006 01:38 AM
Quick Reply: V tail setup
Page generated in 0.11411 seconds with 15 queries
