12s charger ? - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
12s charger ?
Old 08-14-2010, 09:30 PM
Old Sloppy
Old Sloppy's Avatar
Default 12s charger ?
Anybody make a 12s ballance charger ?Would like recomendations from any one who has operated one.I have a 12s 7,400 mah pack I would like to charge at 2c rate.I use three packs and a Plettenberg HP 370BM/A1"s" to make my boat go zoom-zoom on the water.both the Rpm's and the Amps are "Just Right" with this combo. 14s would result in excessive Rpm's so I can't go there.Flight Power ballance taps on everything. a) 5s 7400 b) 5s 7400 c) 2s 7400So I can reconfigure the packs any way needed to charge them up.Right now I charge the 2s pack, then I charge the 10s pack.This takes much longer than I want.Harry</p>
Old Sloppy is offline
Old 08-15-2010, 02:53 PM
philipa_240sx
The biggest I've seen is the iCharger 10 series, up to 10S:
http://www.progressiverc.com/index.p...id=1&Itemid=18
The Revolectrix Powerlab 8 is a close second. 1008W of power and charges up to 8S.
http://www.revolectrix.com/powerlab8.htm
As I do not charge big packs, I don't know how the other guys do it. Perhaps parallel adapters or use multiple chargers to charge packs separately?
philipa_240sx is offline
Old 08-15-2010, 06:38 PM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
To charge a 12S 7400 pack at 2C rate would require the following.
12cells x 4.2volts x 15 amps = 756 watts
The only charger that can do that is the PowerLab8 but like Philipa said, it only does 8 cells max.
If your pack is split - 2ea 6s packs with separate connections to each 1/2 - then you could do it using two PowerLab8 chargers.
Hyperion has a new charger due out sometime later this year that, IIRC, should be able to do it but no release date yet.
Larry3215 is offline
Old 08-15-2010, 07:29 PM
philipa_240sx
He's using 3 separate packs:
I use three packs.... a) 5s 7400 b) 5s 7400 c) 2s 7400
OK, I found you a 14S charger!
The Schulze Next-14-350.
http://www.schulze-elektronik-gmbh.de/next2010-e.htm
She ain't cheap, but Schulze apparently makes good chargers.
If you want to balance the cells, either balance the packs after charging OR make up a special harness to attach to the built in balancer.
Dealers:
http://www.schulze-elektronik-gmbh.de/adr_e.htm
I couldn't find any US retailers with the Next-14 series, but i-Care RC in Canada has them:
http://www.icare-rc.com/chargers.htm
Prices start at $539 US.
Honestly, having 2 separate chargers is starting to look like a less expensive option!
Old 08-15-2010, 11:41 PM
Larry3215
Larry3215's Avatar
Sheesh. Maybe I should try reading the posts before I reply
Old 08-17-2010, 01:58 PM
Poweredge
www.PowerEdgeRC.com
Poweredge's Avatar
Both Bantam (e-Station 902) and Hyperion (1210i) are 12S chargeres but use external balancers and the way you have the batteries split, you can't balance them with external balancers. Your best bet is to split the packs into 2 6S packs and get a dual port charger such as the Bantam BC8DX (200 watts per port) or buy multiple chargers.
Poweredge is offline
Old 08-18-2010, 11:53 AM
philipa_240sx
Didn't even know the Bantam 902 existed as I have not seen it on RCAccessory's website. Not sure where you can purchase these in North America. Here it is on Bantam's website:
http://bantamtek.com/00_eng/02_pro/s...t2=&p_name=902
The Hyperion 1210i is no longer listed on Hyperion's website. But there is a vendor here in Canada that still has some... presumably older product?:
http://www.zebrahobby.ca/cgi-bin/cp-...chargerLithium
Neither of these chargers have integral cell balancers so you need to use external units. In this case two PB6's for the Bantam charger or two EOSLBA10's for the Hyperion.
Old 08-18-2010, 12:23 PM
Poweredge
www.PowerEdgeRC.com
Poweredge's Avatar
The 902 is still a current charger for Bantam, but we do not stock it. www.espritmodel.com and www.gravesrc.com, both here in Florida do have them in stock.
Old 08-19-2010, 01:05 AM
philipa_240sx
Thanks for the information. I had some trouble finding it myself.
Old 08-19-2010, 08:08 PM
supi7
TrueRC.com
supi7's Avatar
Harry, I have a Show Demo Bantam 902 that I can sell you. For the balancing you will also need 2 x PB6 balancers, I can make sure you get all the adapters you need to make it work.
Best Wishes,
Dan
TrueRC
supi7 is offline
Old 08-22-2010, 07:22 AM
calab
Vendor OK Hobby Beware
Try MEGAPOWER 930SR 12S Charger, with external balancer included.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
calab is offline
fishrc
03-04-2010 02:26 PM
Grasshopper
10
06-22-2009 04:45 PM
RoadKingAl
Basement Bargains
06-02-2009 07:19 PM
arrio
06-24-2006 08:16 PM
darkside212
04-28-2006 02:53 PM
Quick Reply: 12s charger ?
Page generated in 0.07914 seconds with 13 queries
