13x6.5 vs 14x6 prop - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
13x6.5 vs 14x6 prop
Old 09-15-2015, 01:14 PM
Flysohigh
electrified
Flysohigh's Avatar
Default 13x6.5 vs 14x6 prop
I want a bit more thrust for takeoff and was thinking on going to a 14x6 prop from my 13x6.5. What can i notice between the change in amps and performance? This is for a suoer cub 25e eflite.
Flysohigh is offline
Old 09-15-2015, 05:05 PM
The 14XD6 will draw more amps. You'll need to do a wattmeter test to verify that its not excessive. This could be a problem for you because you already have an issue with an overheating ESC.
It would give more disc area and therefore more static thrust.
Old 09-15-2015, 05:11 PM
Flysohigh
electrified
Flysohigh's Avatar
Actually i was able to get it in the motorbox as you mentioned and i figured going up on diameter and down .5 pitch will give me more thrust which is what i want for takeoff and slower landings
Old 09-15-2015, 05:16 PM
You would need to trade appx 1.5 inch pitch for 1 inch dia at that size prop to keep the same load. 0.5 is nowhere near the correct trade if trying to keep the same load.
You may have improved the cooling issue of the ESC some, but without baffles to control and direct the air movement over the ESC its not going to be a large enough change to deal with added heat load.
Old 09-15-2015, 05:36 PM
Flysohigh
electrified
Flysohigh's Avatar
So for my case what would you recommend if i want to use a 14 in prop?
Old 09-15-2015, 09:10 PM
Without testing the plane and without using a wattmetr.... I can't make a recommendation.
Old 09-16-2015, 10:59 PM
As a rule of thumb pitch much less than half of diameter gets very inefficient. You are already at that limit with your 13x6.5 so dropping much more pitch and increasing diameter is likely to yield poor results except at very low speeds.
A plane that lands 'hot' usually does so because it's got high wing loading and if you try to slow it down it stalls. Changing a prop wont help with that.
Old 09-16-2015, 11:22 PM
Well... planes can land hot for all sorts of reasons.
CG too far forward and you run out of elevator if you don't keep the airspeed up.
Some designs tend to build speed coming down if you aren't careful. That would be pilot error in how they want the plane to appear as they make the final approach. You should see the bottom of the wing, indicating a slight nose up attitude. If you see the top its diving and accelerating.
Or just being scared of the stall.. from not practicing slow flight and stalls at altitude.
The overweight plane in my avatar pic has a calculated 35 mph "stall" speed. (minimum for sustained level flight.. it can stall at a lot higher) A good approach and it uses less than half the runway vs letting it come in like a bullet.
Old 09-16-2015, 11:38 PM
True, but a finer pitch prop is unlikely to 'fix' any of them.
05-28-2020 09:50 PM
admin
05-07-2020 05:04 PM
Alabama Flying Dude
Pusher Park Jets
05-19-2012 04:13 PM
11-26-2011 10:09 PM
Quick Reply: 13x6.5 vs 14x6 prop
Page generated in 0.06333 seconds with 12 queries
