Battery setup
Old 11-17-2015, 09:19 PM
70sflyer
Default Battery setup
Building the hanger 9 blue nose 60.Motor is e-flight 90,ESC is CC 100.I have 2 A123 batterys I would like to use.4600mah,3S2P.Im not sure if I should hook them up parallel or series. Looking more for longer time flights.Thanks for any help.
70sflyer is offline
Old 11-17-2015, 10:51 PM
Flubber
Flubber's Avatar
Those packs will have to be in series for a 325Kv motor.
Flubber is offline
Old 11-18-2015, 02:31 AM
Turner
Turner's Avatar
I think you will need more cells. Have a look at this thread. Maybe Dennis will chime in and help you out.
http://www.wattflyer.com/forums/showthread.php?t=65583
Turner is offline
Old 11-18-2015, 03:16 AM
60 class plane, with 60 class motor, 6S 3300 to 5000 mah LiPo would be about right...
You're dropping in a .90 class motor though and that needs more cells in series using the LiFe. Its a 6S to 8S motor using LiPo and the LiFe (A123) are about 10% lower voltage. You need 7S to 9S
4600 mah is good.
Old 11-18-2015, 04:05 AM
70sflyer
thanks for that fhhuber,so your saying 4600 mah is ok but i need more cells to make 7S to 9S.
70sflyer is offline
Old 11-18-2015, 04:07 AM
Note that the A123 will be heavier than the same power in LiPo... For some planes that won't be too big of an issue. Not sure about yours.
Old 11-21-2015, 07:04 AM
ramboman
a123 batteries don't need to be removable... they can be used as weight to balance the plane... instead of lead...
ramboman is offline
Old 11-21-2015, 08:20 AM
We always should be using the batteries to balance the plane and avoid adding dead lead...
Old 11-21-2015, 08:33 AM
ramboman
LiPo batteries need to be easily removed to be charged... a123 can be charged in place without risk... that's the difference
ramboman is offline
Old 11-21-2015, 10:11 AM
Generally, ease of removal is not a serious issue.
All but one of the models I have, total weight is more important.
The Proctor Sopwith will probably be better off with the A123 than LiPo because of short nose and needing to stuff more weight forward. Its also looking hard to make a good battery access in that e-conversion.
Its usually more convenient to get the battery to the charger than the whole model. It would be quite the mess to try connecting 4 planes to my charging station at once, but many packs could fit really well.
Old 11-21-2015, 10:35 AM
ramboman
I bring my planes to the charger, to the back of my car...
One at a time, charging at 4c between 2 flights...
ramboman is offline
FlyWheel
Batteries & Chargers
31
05-30-2016 05:44 PM
dongshan
03-01-2013 03:21 PM
SimonXi
08-12-2011 05:08 PM
Howard Matos
FMA Direct
07-28-2011 02:04 PM
12-12-2010 05:50 AM
Quick Reply: Battery setup
Page generated in 0.09604 seconds with 13 queries
