Tricopter ESC position help needed - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Multi-Rotors Discuss your quad copters and other multi engined choppers here.
Old 12-15-2015, 09:21 PM
Paul80
Default Tricopter ESC position help needed
Hi all
Please excuse the Noobie question, I am building a Tricopter and need a bit of help Regarding the position of the ESC on the boom arms, what's best
1. Close to the motor with long battery leads.
2. Close to the Battery with long Motor leads
3. Around the middle of the arm equal distance between Motor & Battery
4. It makes no difference
Thanks for any help with this
Paul
Paul80 is offline
Old 12-15-2015, 10:14 PM
Depends on the size of the esc and the area available near the boom and platform join.
Most DIY's Iv'e seen in the 300 class and larger, the builder tried to get the esc attached as close to the boom (and bottom) of the main PC platform as possible....more than likely as far out of harms way related to (rotor strikes, ground moisture and such).
If you have the boom length and an esc connection point, bottom middle to as close to center body as you can get.....That's my recommendation.
Old 12-16-2015, 12:50 AM
Flubber
Flubber's Avatar
Moving the mass towards the center makes more sense in relation to moment arm and agility. But often the wires weigh as much as the circuit board. Still inboard protects them when the arms are damaged in crashes.
Most of the time i use longer wires to the motors than to the battery (distribution board). Which tricopter are you building?
Flubber is offline
05-28-2020 09:50 PM
06-28-2017 04:22 PM
01-09-2017 02:23 AM
Gridley
ParkFlyers
09-23-2011 01:50 AM
martyp57
22
04-01-2011 07:21 PM
Quick Reply: Tricopter ESC position help needed
Page generated in 0.07633 seconds with 13 queries
