Spektrum DX8 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Spektrum DX8
Old 07-27-2017, 02:35 PM
Ziet
Default Spektrum DX8
Hi, I have setup my HERON with camber and crow etc. I have put crow on the GEAR switch and FLIGHT MODES on the F-MODE switch.
I want to now use the FLAP (3 position) switch for CROW, but I cant for the life of me work out how to do this. Can anybody help please
Ziet is offline
Old 07-29-2017, 06:02 PM
Vic Z
A little out of my league as I don't know what crow is, but I believe that once you get into the setting, drop down to switch option and if you toggle the switch that you want to use it will automatically assign it.
Vic Z is offline
Old 09-07-2017, 11:59 PM
AddictedToFlying
Is this a generation 1 or generation 2 DX8? And help me understand what you're trying to do. You Basically want to just move the gear switch over to the flap switch electronically?
AddictedToFlying is offline
Old 09-08-2017, 12:14 AM
AddictedToFlying
Vic z is on the right track though. It should be about the same for Generation 1 or 2. If you go to system settings and then select switch select or channel assign option. Then look for the gear channel should look like (gear:gear). This means the gear channel on the receiver in the plane goes to the gear switch on the controller. What we think you want is gear:mix . This will make whatever is plugged into the gear spot (crow?) on the receiver/airplane work with the mix switch on the controller.
Old 09-16-2017, 03:24 PM
squidger
squidger's Avatar
Go to your flap mix and highlight the switch you currently have it on then just flick the switch you want it to be and it should change.
squidger is offline
Ziet
07-02-2016 04:23 PM
Company Discussions
10
01-25-2016 09:50 PM
14
12-22-2014 02:57 PM
61
11-11-2014 01:44 PM
Gibbon
03-04-2014 08:59 PM
Quick Reply: Spektrum DX8
Page generated in 0.10724 seconds with 13 queries
