What plane to this configuration? (AXI2820/12, 11.1v 1700mAh Battery, Jeti ECO25 esc) - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 07-27-2006, 12:58 PM
neu
Question What plane to this configuration? (AXI2820/12, 11.1v 1700mAh Battery, Jeti ECO25 esc)
Hey Guys,
I'm just curious what plane would you recommend for this configuration:
Motor: AXI2820/12
Battery: 11.1v 1700mAh
ESC: Jeti ECO 25
It was in my first trainer, but was too powerful, and was not really goor it, as the foam material was weak...(yes, it teared off the nose, even after reinforcing, and I don't want to re-try it and damage the equipment).
So now I'm looking for some plane I could fly with this equipment if possible.
Any ideas are appretiated!
Greeting, neu
www.carrierbuilders.net
neu is offline
Old 07-27-2006, 04:25 PM
Nitro Blast
Nitro Blast's Avatar
Wow,, theres only a zillion planes that will use that power...
Hyperion Cap 232
Hyperion Sukhoi Su 32
AirfoilZ Edge, Yak or Mobius
And nearly all of the Alfa models...
What planes are YOU interested in?
Nitro Blast is offline
Old 07-27-2006, 04:39 PM
neu
Well, the list is:
I'm looking for something scale like (as more close to reality as possible).
- It sohuld be not too hard to fly, as I don't have huge experience yet. Probably I wouldn't break any normal RC plane at first flight, but it's better to be on the safe side, I proceed step by step
- I prefer landing gear landing rather than belly landing
- Pre-made stable motormount is a must, as I have bad memories of flying motors and noses (without the plane ).
- The candidate should be between 1kg and 2kg prefferrably, and about a winspan between 1200-1800mm.
Probably I made the list much shorter by this What Alpha you think is suitable for example?
Greetings, neu
ps: you wanted to write Su-31 right?
neu is offline
Old 07-27-2006, 05:09 PM
Rugar
FAA# OUTLAW!
Rugar's Avatar
Hyperion Cap 232
Huh ? That motor weighs 5.3oz and is suitable to fly a plane in the 2 1/2 to 4 pound weight class. Did you misread which Axi he has?
Rugar is offline
Old 07-28-2006, 04:25 AM
QuietRCFly
QuietRCFly's Avatar
I would have to agree with Gerald. That is for a bigger plane. But I worry that if you run that motor to it's potential, the ESC and battery may be to small. It is recommended you use a 40 AMP ESC with that motor.
Sorry, I was going to recommend the new Hyperion SU-31 25e, as it should work nicely with that motor, but seeing your second post, you are probably not ready for it as yet.
How about the Bonnie 20, from Hobby-Lobby:
http://www.hobby-lobby.com/bonnie.htm
It is more of an advanced trainer. Se the Sport Aviator review:
http://www.masportaviator.com/ah.asp?CatID=1&ID=39
QuietRCFly is offline
Old 07-28-2006, 01:24 PM
neu
The SU-31 seems to be fine, and I like this plane, but I think I'm not skilled enough for this. Probably I wouldn't crash it, but I'd like to have time to enjoy it before I do some dealy failures
The bonnie was drawing my attention too, it's on my list. Seems to be something I need now, an Advanced trainer (and all my stuff fits to it, except the ESC wich I should upgrade anyway as I see)
Any firther ideas are appreciated!
neu is offline
maverickma
Batteries & Chargers
10-01-2008 07:59 PM
Whopper Chopper
01-30-2008 02:56 PM
Sleepy81
01-11-2008 08:43 AM
ELE KIKI
04-11-2007 07:20 AM
zakstang
04-02-2007 02:00 AM
Quick Reply: What plane to this configuration? (AXI2820/12, 11.1v 1700mAh Battery, Jeti ECO25 esc)
Page generated in 0.09333 seconds with 13 queries
