Box/Joined Wing
Old 09-07-2015, 09:13 AM
nuteman
Default Box/Joined Wing
I know some of you like the odd-ball designs, so I thought you might be interested in my latest.
The Elytron was my inspiration for this one, but mine can't do VTOL and it has no wing taper (just sweep). I wanted a single motor, so I made the struts around it to join the two wings.
No camera man available, so the flight video has some gaps.
Specs:
Front wing span: 51 in.
Front wing chord: 8.5 in.
Front wing sweep: 30 deg. (rearward swept)
Rear wing span: 57 in.
Rear wing chord: 12 in.
Rear wing sweep: -15 deg. (forward swept)
Vertical height between the wings: 13 in.
AUW: 49.5 oz.
Wing loading: 6 oz per sq ft
Wing cores: Medium bead styrofoam, cut with hot wire, CF tube spars, MH60 airfoil
Motor: Turnigy D2836/8 (1100 kV)
Prop: 10 x 4.5 "slow fly"
Battery: 2200 mAh, 3 cell, 25C
Best viewed in full screen mode, on a computer monitor:
https://www.youtube.com/watch?v=1K7lbCp2psE
Discussion:
https://www.youtube.com/watch?v=r8NJtJoimIc
Runway take-offs/landings:
nuteman is offline
Old 09-07-2015, 03:20 PM
Bald Paul
Bald Paul's Avatar
That's definitely something you don't see at the flying field every day! Very nice work!
Bald Paul is offline
Old 09-07-2015, 03:24 PM
nuteman
Thanks!
nuteman is offline
Old 09-08-2015, 08:16 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
Well done!
Larry3215 is offline
Old 09-08-2015, 08:29 AM
nuteman
Originally Posted by Larry3215 View Post
Well done!
Thanks!
I hope to put landing gear on it at some point and film it taking off from a nearby asphalt lot - but I might need a stronger motor as the weight is pretty much maxed out for this motor.
nuteman is offline
Old 09-20-2015, 10:21 AM
nuteman
Finally got a chance to throw on some landing gear and try some runway operations. Tried a lighter landing gear system that seems to be holding up very well.
nuteman is offline
Old 09-20-2015, 03:01 PM
Rodneh
Some close up pictures of the landing gear from various angles would be interesting.
Rodneh is offline
Old 09-20-2015, 03:46 PM
nuteman
Oh, I forgot to post the video that shows what I did with the gear.
This should answer your questions. If not, ask away.
Here it is:
nuteman is offline
guapoman2000
Scale E-Powered Aircraft
22
05-26-2016 09:36 PM
30
07-01-2015 11:21 AM
86
01-18-2015 03:21 AM
Off Topic Chit Chat
23
09-23-2014 07:48 PM
paulatgis
26
12-19-2012 12:25 AM
Quick Reply: Box/Joined Wing
Page generated in 0.08315 seconds with 15 queries
