E-foamies Yak 54
Old 11-20-2006, 04:21 AM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
Default E-foamies Yak 54
What a cool little EPP built up plane! The MicroDan 2510 3D motor is superb. Quiet, powerful and comes in a cool orange anodized finish ta boot! This plane will do most anything you ask of it and more. Makes a great throw it in the truck and go huck plane. Will pay for itself after the first few ooops! Little on the pricey side, but I have a few nicer balsa kits laying around awaiting repair, so when you factor in down time or replacement it's well worth it. This one is a must for your hanger if you're into 3D or IMAC. Perfect lunch time practice plane!
Name:	E-foamies YAK 54.JPG
ID:	19250   Click image for larger version
ID:	19251   Click image for larger version
ID:	19252   Click image for larger version
Name:	Battery Hatch 1.JPG
EDFrules is offline
Old 11-20-2006, 06:42 AM
teamjrallen
TeamEFlightBatteries
teamjrallen's Avatar
how can i get one of those planes
teamjrallen is offline
Old 11-20-2006, 08:36 AM
EDFrules
EDFrules's Avatar
www.e-foamies.com I believe. They make an Extra and a new Egde 540 too.
EDFrules is offline
Old 11-20-2006, 04:39 PM
EDFrules
EDFrules's Avatar
Forgot pic of MicroDan 2510-3D. Superior performance and cool color too!
Name:	MicroDan 2510 3D.JPG
EDFrules is offline
Old 11-20-2006, 10:55 PM
andrewgore
I just got one of these this past week. While the plane flies quite well, I am quite upset with the fact that for 105$ (115 if you get the black\yellow as i did), the instructions that come with the model....They aren't even for this kit. They are for their (e-foamies) extra 300 model. While the planes are very similar in build, there are differences that would be nice to have directions for, and not just a single sheet of paper with a bunch of pictures with very vague descriptions.
I realize I may be nitpicking here, but for 100+$, and for how long e-foamies has been making these (and other) models, you would think that they would be able to come up with instructions for each of their models. Also note that its not a full round fuselage, the bottom of it is flat from basically the LE of the wing to the tail.
A suggestion too...make sure your servos are all working well before you glue the plane entirely up. This will make things a bit easier if you need to replace a servo.
I'll see how more flight on it this week goes. Gotta make up a nice little battery hatch like EDFrules shows. The way described in the "instruction manual" shows 1 long slit in the bottom with 2 horizontal cuts at the ends of the long one.......Don't do it that way imo. Just the pressure from bending the EPP away ripped it on my plane. Luckily i've got plenty of EPP still from Slofly stuff
Andrew
andrewgore is offline
Old 11-20-2006, 11:56 PM
EDFrules
EDFrules's Avatar
Someone inspecting my hatch at the local flying field tore the EPP "hinge" and now I'll have to reinforce by gluing on some strapping tape with UHU glue. Lack of, or dissamiliar instructions are really not a big deal cuz this is about as simple as it gets but yes, I would agree this one and a lot of other manufacturers leave a lot to be desired in the instruction department. Of course we all go online to the forums for the real build tips when we grab a new model and have questions. It seems like every model I've built has needed some type of mod or whatever to keep it in the air as long as possible. If you don't do one thing or another to them they will end up buried in the dirt. Just once I'd like a no brainer where you don't have to figure anything out, just assemble and fly! Yeah, and then my alarm clock went off!
Andrew
EDFrules is offline
Old 11-21-2006, 01:04 AM
andrewgore
haha yeah, I feel the same way. Overall the build wasnt bad at all. I wouldn't mind it if companies beveled the control surfaces either. Shoot, I'd even pay 10-20$ more for a plane if this was done. Little details like that are what I think make a more expensive plane worth it. Guess I'll get to designing up a nice little fixture for cutting the bevels. Time to go mod up that battery hatch
Andrew
proffcharlie
3D Flying
13
09-24-2007 06:16 PM
Harleyflyer
3D Flying
09-22-2007 02:07 AM
ARTP47
ParkFlyers
07-24-2007 05:26 AM
ENUT
3D Flying
29
06-26-2006 09:51 AM
Harleyflyer
Foamies
09-07-2005 04:19 AM
Quick Reply: E-foamies Yak 54
Page generated in 0.12781 seconds with 19 queries
