Two New Receivers - comments and test results
Old 10-03-2005, 11:50 PM
NCguy
Default Two New Receivers - comments and test results
Anyone had any experience with the two new receivers from hitec and mikrodesigns?
http://www.mikrodesigns.com/rxo.htm
http://www.hitecrcd.com/homepage/product_fs.htm
NCguy is offline
Old 10-04-2005, 05:08 PM
buzzbomber
Matt Smith
buzzbomber's Avatar
NCguy, I haven't flown with my new Hitec yet, but I bought an 05FS a few weeks ago from Balsa Products. It's nice and compact and light. It range checks okay, so I imagine it will be pretty bulletproof, as are the HFS04 and 05MGs that I have.
buzzbomber is offline
Old 10-07-2005, 11:35 PM
GeraldRosebery
There is no such thing as a reliable single conversion reciever. Unless you find your aiplanes boring and wnat to be them broken I simply won't recommend using them. I think they should be outright banned.
GeraldRosebery is offline
Old 10-08-2005, 12:20 AM
NCguy
I've got to disagree with you there and I'm not sure what your remarks are based on other than some possible bad personal experiences. Most of my older single conversion berg receivers are at least as good as my dual conversion receivers. If the hardware and especially the software are done right single conversion DSP offers many advantages over the traditional non-DSP receivers.
I just ordered two of the mikrodesigns receivers. I'll let you know how it goes. My old standby used to be berg but berg isnt what it used to be.
NCguy is offline
Will Hicks
Dealer
Will Hicks's Avatar
Your right, those Berg and JR receivers are crap
Will Hicks is offline
Old 10-08-2005, 12:25 AM
NCguy
Berg is being totally reworked and manufacturing moved to CC's new facilities now that they have outright purchased berg. CC claims that all the problems have been remedied. That remains to be seen as well as when CC will finally release the product. In the meantime I'm in search of a solid, 5+ channel micro receiver in the $50 price range. I'm hoping the mikrodesigns fits the ticket.
NCguy is offline
Old 10-08-2005, 01:42 AM
Turbojoe
Mountain Models Minion
Turbojoe's Avatar
Boy, I'm with Gerald on this. I have yet to see a reliable SC RX. I've had nothing but trouble with GWS and Cirrus RX's. I've never had one but I've seen several planes crash from complete loss of control with Bergs. I've yet to have a crash that I could blame on any of my Electron 6's! I've damaged some in crashes but they weren't the cause of the crash.
I thought I'd give SC one more chance and got the Hitec Micro 05S RX to try in a small wing I have. Another big mistake. Glitch city. Not as bad as GWS or Cirrus though. The plane flew completely glitch free with an Electron 6. I've got 10 Electron 6's now. I'm thinking about one of the Polk Seeker RX's simply because they are synthesized. I'm sick of buying so many crystals.
Joe
Turbojoe is offline
Old 10-08-2005, 01:48 AM
NCguy
Joe
I've got a sombra shadow 3 synthesized. Nice! I'm just looking for a $50 receiver otherwise I would buy all shadow 3's.
Thanks for your feedback on the hitec. So far I'm hearing more positive feedback on the mikrodesigns vs the hitec.
NCguy is offline
Old 10-08-2005, 01:57 AM
Turbojoe
Turbojoe's Avatar
HERE is your under $50.00 RX. I'd like to try the Sombra's but they're pretty pricey.
Joe
Turbojoe is offline
Old 10-08-2005, 02:00 AM
NCguy
Joe
Nice but I honestly believe a postage-sized 5 ch receiver at 4-8 grams can get the job done just fine.
NCguy is offline
Old 10-08-2005, 04:32 AM
soarr
Glider guider
I have a Hitec HFS-04MG in a Slow Stick and in a Cermark Newtimer and have had no problems flying them until they're almost specks in the sky. I can't comment on the new Rx from Mikrodesigns but I have one on order.
M
soarr is offline
Old 10-08-2005, 06:49 AM
mle2tie
chief button pusher
i fly w/ single conversion recievers.
i have yet to have any serious problems.
but then again i:
dont do allot of aerrobatics
i dont fly w/ anyone else (i have an odd work scedual)
i dont fly near any high energy tx ( cell phone, am/fm radio, tv towers and or sat uplinks ) i know that the atmosphere is alive w/ radio interference.
i did fly in front of a marty(sp) tx i think. vhf or uhf not shure marty antennas are very distinctive looking. flying infront of the marty antenna locked up my plane. once it the plane flew out of the line of sight for the antenna control was restored.
i fly w/ gws 4ch single conversion ( eva bipe and flashback) and jr r610m( SA Squirt 400) and a hitec feather 555( test rig) a jr radio and futaba tx
no probs as yet
mle2tie is offline
Old 10-10-2005, 04:46 AM
uglyplane
Ugly planes fly better..
uglyplane's Avatar
I fly helis and they are more demanding of RX's than planes. I have Hitec Electron6's, Bergs, JR's, FMA's. The Berg solved a glitching problem I had on a heli, the prev RX was an Electron 6. My Hitec have been bullet proof in planes.
I wouldn't give you 2 cents for GWS...Two planes had them and I couldn't trust them. I also had the first gen JR610 and they were no good. All other JR's have been flawless...
uglyplane is offline
Old 10-10-2005, 05:38 AM
funnysticks
Default Hitech ok
I am using a hitech feather reciever w/hitech servos on a futaba xmtr. and have good ground range and very good air range. I have found that a lot of glitching can be eliminated by keeping ant. wire as far away from all other wiring. Even the servo leads close to the ant. can give problems.
I always try to plan reciever location to allow the ant. to leave the fuse. at right angles and then route it to the rear of the plane. Our electrics do generate a lot of RF noise and FM recievers do a pretty good job of rejecting most of it. AM recievers are not as good rejecting noise.
A quick check for RF noise is to hold an AM portable radio tuned to a clear spot on the dial next to your plane while running the motor at various speeds. Another fix is to be sure that all the wire leads are twisted together where practical. This will reduce the RF radation from them.
Hope this will help some of the glitching. Dan
funnysticks is offline
Old 10-26-2005, 06:45 PM
no stick
Here is your under $50.00 full range dual conversion lightweight Rx. I've got two of them and they are rock solid.
Ed
no stick is offline
Old 10-26-2005, 08:37 PM
Unbalanced prop
Watt, No fuel?
Unbalanced prop's Avatar
Ed
I agree, nice receiver at a good price. Just wish channel 5 could be used as channel 6 to use dual aileron servos like the 5 channel Bergs and the 5 channel mikrodesign.
Doug
Unbalanced prop is offline
Old 10-26-2005, 10:16 PM
qban_flyer
Guest
Posts: n/a
Thumbs down
My eleven three year old GWS Pico & Hitec Feather receivers might not be aware of what you are talking about, yet!
I use a Pico on a very fast (better than 60MPH) delta model and so far it is still in one piece. Either I got all the good ones or you got all the bad ones made.
Old 10-26-2005, 10:21 PM
qban_flyer
Guest
Posts: n/a
So well put. I agree and to thank you for coming to the Feather's rescue!
It's all about installation neatness and proper distribution of the components within the airframe. Keep that RX as far away from the motor and ESC as possible.
Old 10-26-2005, 10:26 PM
qban_flyer
Guest
Posts: n/a
Ed
It's a very nice RX. I own two of them also, but won't use them in my $75 (RTR) park flyers. For most of those I have the $24.50 Feather.
I also own their Extreme 5 and Fortress RXs. Reliable and priced just right.
Old 10-27-2005, 01:47 AM
LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
I've had problems lately with hitec 555's. Sending two of them back to hitec. On one in a katana foamy while up about 50 feet, it lost signal.
Didn't have any control at all. Plane crashed. Tested rx...got nothing.
Seems like the circuit board failed. Same thing with the other 555. Get absolutely nothing.
My other rx's, M5, Berg micro stamp, big futaba 8 channel have had no problems. Especially the berg. Its antenna has been pulled out twice. Its been in a tree for 3 weeks etc. Still performs with no glitches. Heck, I even use the M5 in glow planes. Works perfect.
Dave...
LuckyArmpit is offline
Old 10-27-2005, 02:07 AM
qban_flyer
Guest
Posts: n/a
Lightbulb
Dave...
I have always found FMA's products to perform to specs or surpass them. I am using their servos, Co-Pilot, ESCs, Batteries and receivers. Absolutely reliable in every way.
I also have Hitec, GWS, JR and Futaba TXs as well as RXs. No problems with those either.
Old 10-27-2005, 05:04 AM
kalel
qban,
is it to heavy for your park flyers, or it is glitchy? I am wondering because I am in the market for one right now.
Thanks,
Kalel
kalel is offline
Old 10-27-2005, 05:35 AM
qban_flyer
Guest
Posts: n/a
Lightbulb
Originally Posted by kalel View Post
qban,
Thanks,
Kalel
Oh! no, I just don't put full range RXs in my park/3D/indoor flyers. I'm going to be flying them within 50-75 feet from me, so why waste a nice full range Rx on "up in my face flying"? Though I'll have to admit I have a Fortress in my G/P Yak-55.
I use them on sailplanes and larger electrics where I may get the model up in the air several hundred feet high.
Mike Parsons
Test Posting Forum
19
03-02-2012 11:38 PM
Larry G
Warbird Electrics
08-04-2008 03:10 AM
SmoothCruizer
Electric Ducted Fan Jets
9
07-22-2008 05:55 AM
Dave S
06-04-2006 05:22 AM
JustGoFly.com
11
10-17-2005 06:19 AM
Quick Reply: Two New Receivers - comments and test results
Page generated in 0.19284 seconds with 13 queries
