pz spitfire brushless problem
Old 09-08-2007, 02:43 AM
RandolphNav
Default pz spitfire brushless problem
hey all,
maidenered my pz spit with a brushless series six 2700 and had no problems until the pinion gear came off. I tightened it as much as I could with the apex tool and it still came off....should I use locktite or glue the pinion gear to the shaft? flew like a champ for 1 minute lol...went nose down into the ground. Luckily, the brushless motor and speedcontroller were undamaged, same with the frame.
RandolphNav is offline
Old 09-10-2007, 01:27 AM
Pig
Pig's Avatar
If it's a typical pinion gear mounting via small inset screw, do yourself a favor and carefully file a flat spot on the shaft. You don't need a giant divot, just a small flat spot. Use the blue locktite on your set screw and give it a good 12 hours to dry and you should be set.
Pig is offline
joeted
Warbird Electrics
525
06-17-2010 03:33 PM
thehaze
Warbird Electrics
05-09-2008 04:58 AM
Cheese_Puddin
Warbird Electrics
03-18-2008 11:30 PM
mikidymac
Warbird Electrics
01-10-2008 11:15 PM
Larry G
Warbird Electrics
11-29-2007 02:47 AM
Quick Reply: pz spitfire brushless problem
Page generated in 0.06909 seconds with 13 queries
