Park flyer spitfire, balsa
Old 09-29-2007, 10:55 PM
guest001
On Hiatus
Default Park flyer spitfire, balsa
Can anyone direct me to a park flyer, balsa spitfire arf? Something like the Hyperion, but a 10e, not a 25e. Thanks
guest001 is offline
Old 09-30-2007, 12:10 AM
Frank Voikel
Frank Voikel's Avatar
Here you go.
Frank Voikel is offline
Old 09-30-2007, 12:54 AM
guest001
On Hiatus
Thanks, Frank: that's just the ticket!
guest001 is offline
Old 10-13-2007, 05:28 AM
FlyBri
FlyBri's Avatar
I have the ripmax spitfire. If that one flyes like this one you cant go wrong. I lucked out and got this one a fwew weeks ago.
with E-flite power 10 and 3cell 2070 AUW 38 Gets 7-9 minutes depending on throtle managment.
Absolute dream to fly
If gravity gets the best of this one I would get the HK Spit
Name:	spitfire 1 72.jpg
FlyBri is offline
Old 10-13-2007, 11:46 AM
haze_b
haze_b's Avatar
Yes!! The Ripmax Spit is a great option.
Looks great "as is" and easy to "bash" if you want it more scale. I scaled the cowl (replaced the weak motormount with a drilled out basswood block flush, against the firewall) and installed Robat 600 retracts in the scale location.
Flies great with an Axi 2826/10, CC Phoenix 45, 3S TP extreme 2200 and 11x8.5 APC prop.
Here a couple of pics of my Spit
ID:	44527   Click image for larger version
haze_b is offline
Old 10-13-2007, 02:00 PM
FlyBri
FlyBri's Avatar
That looks good haze b. Very nice work you have done there. How do the retracts hold up on grass?
Brian
FlyBri is offline
Old 10-13-2007, 05:37 PM
guest001
On Hiatus
Let it be said at the outset, that this is no parkflyer. Well, maybe once you get thoroughly used to it, because it can be held to a rather small airspace, but that's going against its nature and is no fun. What you want to do is dive down and flash past at speed, or come in on a low strafing run that ends with a steep climb and a victory roll, and you want enough space so you don't have to sweat your landing.
Above from the review.
Thanks for the suggestions but a few of us are looking for something small, like the 10e class from Hyperion.
I guess it's off to United Hobbies!
guest001 is offline
Old 10-13-2007, 08:47 PM
haze_b
haze_b's Avatar
Wink
Just trying to give you some options to think about.
I guess it depends on your persception of what "small" is and what a "parkflyer" is.
The people I fly with certainly consider the a RIPMAX Spit a parkflyer. And yes, if you have the skill, you can do all the high speed - low passes, steep climbs and victory rolls you like. (along with all the other common aerobatics that warbirds can do.)
I checked out that UH Spit. It looks eerily like the RIPMAX, maybe a little smaller. Nice choice for $89 bucks
haze_b is offline
Old 10-13-2007, 09:03 PM
guest001
On Hiatus
Small is defined by the spaces we must use: again, the 10e series of Hyperion models is about right for us.
Thanks for the options!
guest001 is offline
Old 10-13-2007, 09:52 PM
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
World Models makes one.....39.5" wingspan.
http://www.airborne-models.com/html/...p?ProductID=93
Biplane Murphy is offline
Old 10-13-2007, 10:31 PM
FlyBri
FlyBri's Avatar
The Hyperion models 10e is more like a 400 size in comparison to like E-Flite 10 modles ( Brio) and the Hyperion 25e is nothing like the E-Flite 25 size models ( AT-6 Texan)
Wish there was more of a standard to go by
there are not many balsa built warbirds in this size, choices are very limited, most Hyperion 10 or others 400 size warbirds are motley foam. the World models seems to be the ticket for ya if you want a 400 size electric plane.
FlyBri is offline
Mr C
Warbird Electrics
07-13-2008 09:49 PM
pburt1975
56
04-02-2008 03:29 PM
Flyer 1
ParkFlyers
8
07-24-2006 08:10 PM
Cessnadog
ParkFlyers
03-29-2006 02:00 AM
flyranger
ParkFlyers
02-15-2006 10:54 PM
Quick Reply: Park flyer spitfire, balsa
Page generated in 0.11984 seconds with 17 queries
