Electric conversion of Kyosho Spitfire 40/90 + sound system
Old 03-16-2008, 02:53 AM
modelsolutions
Model Solutions of Canada
Default Electric conversion of Kyosho Spitfire 40/90 + sound system
Hi, In order to demo my sound effects system I would like to install it in a Spitfire and was thinking of the Kysoho ARF Spitfire 40 or 90 with a conversion to electric propulsion.
I have two questions :
1) Can anybody recommend an electric power plant, battery and ESC for both these models and tips on how to do the conversion.
2) My sound system may weigh in at about 13oz. Would the smaller 40 size be able to handle that payload or would I have to go to the larger 90 size?
Thanks,
David
modelsolutions is offline
Old 03-16-2008, 05:57 AM
haze_b
haze_b's Avatar
Aloha,
I'd recommend the .90 size Spit as you wil probably need that much nose weight (13oz) to balance it anyway. (Adding 13 oz of dead weight to a .40 size plane will likely make it a brick.)
As far as a power system, consider the following as a starting point. (keep in mind there are lots of alternatives)
Motor: E-Flight Power 110
Battery: 8S 5000mA pack. (20C discharge rate or better)
ESC: Castle Creations Phoenix 85 HV (you will need a flight battery or UBEC for servo power)
Just my 2 cents,
Good luck
haze_b is offline
Old 03-16-2008, 06:00 PM
modelsolutions
I appreciate your feedback,
Thanks,
David
Twmaster
09-10-2010 11:46 PM
modelsolutions
09-13-2009 09:30 PM
arcflyer
Test Posting Forum
04-07-2008 09:12 PM
hookedonflyin
18
03-07-2007 10:19 AM
russlew
12-03-2006 04:05 PM
Quick Reply: Electric conversion of Kyosho Spitfire 40/90 + sound system
Page generated in 0.12418 seconds with 12 queries
