Repairing foam warbirds
Old 08-02-2008, 07:10 AM
gene465
gene465's Avatar
Default Repairing foam warbirds
Heya new to planes and I was wondering what is the best way to repair the foam warbirds. I sheared off about and inch or so on the wing tips of a Sea Fury 400 when I maidened it. I had the aerilons reversed! Anywho it has been glued back together again and flys well and I would like to repair it. I see people using spackle to fill in low spots and such but what do you do to repair wing tips and such. Thanks Gene
gene465 is offline
Old 08-02-2008, 10:27 AM
Destroyer of airplanes
Airplanes Fear Me-AMA7474
Destroyer of airplanes's Avatar
Gene,
Foam repairs are fairly simple. You can epoxy a small block in place of the damaged wing tip and quickly carve the block to a rough ready shape for final sanding. It's quite easy.
Paul
Destroyer of airplanes is offline
Old 08-02-2008, 02:33 PM
baz49exe
baz49exe's Avatar
Gene,
A flying buddy of mine totalled his art tech P-51. He carefully collected up all bits of foam and slowly reconstructed it using white wood glue. It looks like new. Amazing stuff foam!
Barry
baz49exe is offline
Old 08-02-2008, 06:16 PM
gene465
gene465's Avatar
Paul, Barry thanks for the tip! Anyone recommend a sandpaper grit and the best tool for carving foam? Thanks again Gene
gene465 is offline
Old 08-02-2008, 10:16 PM
Larry G
E-Pilot
I was using 80 grit for real rough shaping, then 120 when I got closer, and finished up with 240. Some types of foam seem to sand better than others. Parkzone Z foam didn't sand well for me.
The lightweight spackle worked well for me. Needs to be thinned a bit with water to make it more spreadable.
Watch sanding at the glue joint. The glue is much more sandpaper-resistant than foam, and you can end up with a raised hump. I even took my Dremel tool and carefully ground down the glue to get it flat.
Larry G is offline
Old 08-02-2008, 10:53 PM
Voyager2lcats
Friend Across the Water
Voyager2lcats's Avatar
I will agree with Larry. Rough sanding with coarse sandpapers or even using a razor saw, small hacksaw, etc. are good for cutting and shaping the foam replacement blocks. I have found that it helps to cut with a razor saw along or near a foam edge or surface that has been warped by impact or shipping damage and then Gorilla glue it together and use painter's tape to get it aligned properly. Pull the painter's tape off when it's dry and you can saw any excess glue off with the razor saw. Most of the time, the painter's tape holds the Gorilla glue back and it's pretty much flush with the surface of the adjoining foam. If you get an uneven surface from all that cutting and sanding, then vinyl spackle is your friend- it's very light and you mix it up with water and either paint it on with a foam brush, 1/2" wide paint brush, or use a wooden tongue depresser(!). I have been using 400 grit wet/dry sandpaper and even 600 grit to get a really smooth finish on most foam (EPS and Depron). I have never used Z-foam, so I can't offer any help in that area. I hope this helps.
Bob
Voyager2lcats is offline
Old 08-05-2008, 06:11 AM
gene465
gene465's Avatar
Thanks all, almost got it all fixed up! now to find some matching paint! Gene
gene465 is offline
scottn3n
New Product Announcements
9
12-02-2007 08:00 PM
mjohnston23
06-03-2007 04:53 AM
Critical Mach
Crash and Safety Forum
05-21-2007 07:55 PM
2muchfun
ParkFlyers
42
09-19-2006 12:33 AM
swapdaddyxx1
09-03-2006 12:26 AM
Quick Reply: Repairing foam warbirds
Page generated in 0.13123 seconds with 13 queries
