Elemodels fans with outrunners
Old 08-22-2006, 04:26 AM
easytiger
Banned Permanently
Default Elemodels fans with outrunners
http://www.elemodel.com/shop/?gOo=Z2...3Q&goodsid=965
Anybody try one? 25 ounces of thrust from a 55mm fan, with an outrunner included, for $30 or so...
High amps quote
easytiger is offline
Old 08-22-2006, 04:36 AM
darkside212
darkside212's Avatar
When I get one in for testing I will let you know what I think. So far I have been VERY impressed with the ELE motors
darkside212 is offline
Old 08-22-2006, 04:38 AM
darkside212
The only issue I have had with the high KV outrunners is: they are not compatible with the towerpro or Dynam ESCs
But I will have the ELE advanced series ESCs in for testing (they are compatible with high kv outrunners)
Old 08-22-2006, 04:40 AM
darkside212
BTW look at the Temps of the motors...those are in DEG C which the one that is 94C is almost boiling
easytiger
Banned Permanently
Seems like MUCHO thrust for very little moolah and size...40amps, but they have a 40a esc for super cheap...but what battery, is the question? And what will it do on three cells? I suppose the 25 ounces of thrust is on four cells, and four cells won't let you use the esc's BEC...
Old 08-22-2006, 04:41 AM
easytiger
Banned Permanently
Will they work with the other ELE series, the cheaper ones?
The temp does not bother me...that's still probably a lower temp than a Cox Baby Bee!
Old 08-22-2006, 05:16 AM
darkside212
No they will only work with the advanced series ESCs which are a little more $ but still a pretty good price. The issue is the timming..the high kv outrunners are "too fast" for a "cheap escs" and they get confused on startup causing sporadic jerky movements...I found that out testing the ELE460FX, but others report the same issue with the JGF450TH:
http://www.rcgroups.com/forums/showt...er+esc+problem
they do work with: CC, and Quark escs though...I tested with those and they work great
One thing you should consider (if you didn't know) the shipping from China can take a while. Even EMS can take while...my last EMS took over 2 weeks ...but I think it is just luck of the draw..it can be slow or "fast" depending....
Old 08-22-2006, 05:23 AM
easytiger
Banned Permanently
Kevin at Elemodels is recommending their 60a Advance...wonder if that is overkill? I can use it in other models anyway, and the price is good...
I'm glad you said something, though, as I WAS going to use a Dynam ESC!
Old 08-22-2006, 05:35 AM
darkside212
Kevin is a really nice guy
the 60 would be a good choice..that'll cover all the bases if you need it...If you can make it with a smaller get that later
I plan on carrying the ELE advance line in the future
Old 08-22-2006, 05:39 AM
easytiger
Banned Permanently
Have had very good luck with EMS from China so far...
What is starting to concern me is this:
Fan and motor:71g
Battery: 189G
ESC: 55G
Total 11.25 ounces.
Not really appropriate for the 25" Babycat...
No free lunch, I guess. If I can go with a smaller batt and esc?
Old 08-22-2006, 06:34 PM
darkside212
You might be able to shave some weight in the Batt/ESC dept
a lot of times the data they give is wrong....thats why I test em' myself...sometimes I get better results..sometimes they are worse...
Old 08-22-2006, 07:04 PM
easytiger
Banned Permanently
Just what I was thinking. I will wait till you test them.
To get 25 ounces of thrust sounds good...to pay 12 ounces to get that...not so good!
Old 08-23-2006, 12:19 AM
darkside212
BTW the 60A does NOT have a BEC..so you would have to account for that weight as well
Another option I've been playing with would be the ELE460FX I mounted it in a gws EDF55 and got REALLY nice thrust and only drew 17A!
Ino it isn't close to the "600W" setup ele has..but for a smaller app it might work great.
I would really like to get a different fan housing to test that motor in...any leads?
Old 09-07-2006, 06:55 AM
Bill G
Super Contrubutor
Bill G's Avatar
Wonder if it would fire up twins on a single 60A ESC? The CC25 fires 'em up pretty easily, with a bit of derating.
From what Darkside stated, it seems like an Advance 18 would work?
The25oz spec looks good, if its correct. GWS 55s give about 22.5oz with a Maxx 2025-5300, at more than 17A, probably closer to 25A.
Bill G is offline
Old 09-07-2006, 01:48 PM
ExtremeRC
Rocket Man
ExtremeRC's Avatar
A GWS EDF55 with a 5300Kv motor will pull alot more than 25 amps!!
I have run 5000Kv Hyperions in the EDF55, on 2s it pulls 17 amps for around 400 grams initial thrust, on 3s it pulls 35 amps!
The sweet spot for the EDF55 is around 3600Kv.
Darkside how did you fit that 460FX motor into a GWS EDF55?? Motor is 27.8mm diameter, EDF55 is 24.8mm diameter housing...
ExtremeRC is offline
Old 09-07-2006, 01:52 PM
darkside212
hehe I mangled the mount and used long bolts...also I bored out the hole on the impeller adapter...I was pulling 17A and thrust was GREAT
I really think the ELE460 would be great in a fan that it can fit in...
I'm really not impressed with the ele DF (by the looks of the specs) and for me to test it would be pointless IMHO
Old 09-08-2006, 04:33 PM
darkside212
Well things have change :p
ELE is sending me the 5300kv EDF setup for testing I will post my results here, on RCH, and on RCG.
know that I do sell ELE products, so I might be biased JK
I no reason to manipulate any data as I wouldn't even have the EDF's instock
Old 09-08-2006, 04:36 PM
darkside212
I did speak with ele in regards to the supplied outrunner: I do have the 2409 2900kv outrunner which is ok...I put a 5.7*3 APC on it and got decent power low temp,and low amps with it....Hopefully the outrunner supplied with the EDF is as good
Old 09-09-2006, 03:44 PM
ExtremeRC
Rocket Man
ExtremeRC's Avatar
I would like to see definitive thrust tests on a test stand, combined with volts, amps and RPM, this way we can see the efficiency of the motor aswell.
My hand wound 24mm Diameter outrunner pushes 430 grams thrust in the EDF55 at 17.5 amps and 10.5 volts. Thats alot of thrust from a fan housing with no eflux tube.
Old 09-09-2006, 03:50 PM
darkside212
agreed..the specs on the ELE site do not mean much when the motor is at almost boiling temps
for the most part: edf's aren't really that efficient
Crash Test Dummy
18
07-09-2008 08:09 PM
ltbidrawn
Warbird Electrics
05-30-2008 01:07 PM
Humor
10-02-2007 01:15 AM
crash86
12-09-2006 05:25 PM
eal757
Electric Ducted Fan Jets
04-10-2006 05:32 AM
Quick Reply: Elemodels fans with outrunners
Page generated in 0.09616 seconds with 13 queries
