Scorpio Hellcat CG?
Old 06-07-2007, 05:02 AM
Twmaster
Registered User
Twmaster's Avatar
Default Scorpio Hellcat CG?
Hi folks,
Got a nice used Scorpio Hellcat. Just need to put an RX in her and set the CG. One problem. No instructions.
Anybody got a manual they can check the CG location for me please?
Thanks!
Twmaster is offline
Old 06-07-2007, 05:30 AM
Grasshopper
Some Assembly Required
Grasshopper's Avatar
Hi Mike,
Would love to see pictures of the Hellcat. Don't see a lot of scorpios posted.
Grasshopper is offline
Old 06-07-2007, 05:36 AM
Twmaster
Registered User
Twmaster's Avatar
Ok Tom here's a pic for ya.
It's all stock. Long can 400 motor, 10 cell NiMH, 4 servos. I'd like to fly her this weekend.
Twmaster is offline
Old 06-07-2007, 05:38 AM
Grasshopper
Looks great. What's the wingspan on it? Make sure and let us know how it flys. Good luck with the maiden.
Old 06-07-2007, 05:41 AM
Twmaster
Registered User
Twmaster's Avatar
It's a 40" span bird. Can't fly with out the CG....
Twmaster is offline
Old 06-07-2007, 05:50 AM
Twmaster
Registered User
Twmaster's Avatar
WOOT!!
A fellow flying buddy just emailed me scans of the manual!!
Just in case anybody needs this info later on it's Step #53 in the manual and says 70-80MM from the leading edge at the wing root.
Twmaster is offline
Old 06-07-2007, 05:53 AM
Jagzilla
I fly for Beer
I used to have one of those, and I'll tell you, that is one sweet flyer of a warbird! I still miss mine!
J
Jagzilla is offline
Old 06-07-2007, 05:54 AM
Grasshopper
Here's a link where Doppleganger says he has instructions.
http://www.wattflyer.com/forums/showthread.php?t=512
Old 06-07-2007, 05:55 AM
Grasshopper
Oops too late.
Old 06-25-2007, 04:07 AM
pmpjohn
Dr John
The Scorpio Hellcat is a very sweet flyer. To bad HL does not import it any more even if it was a bit pricy for a foamy. Mine was given to me by a friend but missing the motor/gearbox that I would not have used anyway. I am using a Himax 2816, CC25 and 2100mah 3s lipo. I built mine without landing gear, who wants to see a warbird with the gear hanging down? Easy hand launch and floats in on her belly. I added panel lines, guns, weathering,cocpit detail and proper markings. She is one of my regular go to birds.
John
pmpjohn is offline
Old 06-26-2007, 08:44 PM
alex242
I got one of these, but now it's called GELCAT. Its a little fragile, so be gentle with landings, otherwise she'll be covered with epoxy like mine. The Nippy Black 1608 with lipos just rocks, so epoxy is not a problem.
I build it with removable wing and a little reinforcement where tail meets the fuse. Also put a layer of thin fiber inside the cowl.
alex242 is offline
Old 06-27-2007, 01:07 AM
pmpjohn
Dr John
I guess you could call mine a glascat. I used 3/4oz glass cloth and Minwax WBPU on the whole inside and bottom outside of the fuse. The balsa stringers down the sides were extended back to the tail. The wing is hard mounted but I cut a large access hatch into the top of the fuse. She will just float in for a landing so slow that she will not hardly slide at all after touchdown.
John
pmpjohn is offline
Old 07-05-2007, 02:08 AM
booger
Default Scorpio Hellcat maiden on 4th of July
just finished it off today and had to take it for a fly
4-Hs-55 servo's
electron 6 receiver
Jeti spin33 speed control
Ep 2200 20c 3cell battery
ELE EC35P-M motor
apc 9x6 prop
flew like a dream and I have maiden video
http://media.putfile.com/Scorpio-Hellcat-maiden-flight
booger is offline
Old 07-07-2007, 02:32 AM
alex242
nice video!! Sounds great!
alex242 is offline
Old 07-30-2007, 12:16 AM
Strick
Default Got One!
Just got a Scorpio Hellcat today. Any advise or leads to threads would be greatly welcome!
Strick
Strick is offline
Old 07-30-2007, 04:15 AM
alex242
Not a build thread, but lots of tips.
http://www.rcgroups.com/forums/showthread.php?t=463667
http://www.rcgroups.com/forums/showthread.php?t=119490
alex242 is offline
Old 07-30-2007, 10:14 AM
Strick
Thanks Alex 242, those threads are a big help! Had not thought of searching for Hobby Lobby Hellcat.
Strick
Strick is offline
Old 09-20-2007, 04:57 PM
magneso
magneso
Hello.
I have a Spitfire kit but no instructions. Would you be so kind as mailing me the instrions for the Hellfire, I understand they are the same as for the Spitfire.
Regards Magne
magneso is offline
f86esabre
09-05-2008 08:06 PM
easytiger
Electric Ducted Fan Jets
03-18-2006 06:23 PM
Darrell_F
Ebay for sale
03-03-2006 05:10 PM
232cap
02-07-2006 03:32 AM
Quick Reply: Scorpio Hellcat CG?
Page generated in 0.10536 seconds with 17 queries
