Parkzone Spitfire
Old 09-10-2007, 10:02 PM
amgar
Question Parkzone Spitfire
Does anyone know if you can change the standard radio gear in the Parkzone Spitfire and fit either 2.4 ghz or 35mhz (with micro servos and receivers etc)
Is there enough room?
Thanks.
amgar is offline
Old 09-13-2007, 03:36 AM
Couture
You can do just about anything you want..... Getting the original servo out of the wing is a pain as it is glued in. With a little inginuity, it can be done. You might as well upgrade the motor as well and go brushless. Any 3500kv ish inrunner will be fine.
Couture is offline
Old 09-13-2007, 04:21 AM
Frank Voikel
Frank Voikel's Avatar
The 2.4 ghz stuff will be smaller than your current stuff, so it should fit just fine. It'll take some effort to get it all pretty again after you tear out and replace the wing servo. Any questions, just post them here.
Also, you could potentially start a new thread if/when you do the conversion for people to read later on if they're planning on making a similar conversion of their own.
Frank Voikel is offline
Old 09-13-2007, 10:48 PM
herk_1
Trash Hauler emeritus
herk_1's Avatar
You wouldn't have to replace the servos because it uses standard 3-wire servos.
herk_1 is offline
Old 09-13-2007, 11:02 PM
Frank Voikel
Good! I (unwisely) assumed that the Spit used the HZ/PZ 5 wire servos... my mistake.
gfdengine204
gfdengine204's Avatar
Now THAT sounds like a perfect fix!
gfdengine204 is offline
PerlAddict
Warbird Electrics
430
10-02-2013 04:46 PM
Spitzfiya
Warbird Electrics
27
09-13-2007 08:23 PM
amgar
Foamies
09-11-2007 04:12 AM
dmmalish
Warbird Electrics
07-13-2007 12:17 AM
pilgrim pete
Warbird Electrics
11
02-01-2007 10:53 AM
Quick Reply: Parkzone Spitfire
Page generated in 0.13772 seconds with 13 queries
