Replacement ESC for HZ SuperCub
Old 09-17-2010, 07:39 PM
deltbro
Default Replacement ESC for HZ SuperCub
I am in the process of changing my HZ SuperCub over to new electronics including the DX6i. Any recommendations for a cheap ESC to run 3S lipo on with the stock brushed motor? Anyone have anything that they want to part with?
deltbro is offline
Old 09-17-2010, 08:21 PM
Turner
Turner's Avatar
I've been using the 30amp Turnigy with the stock motor for nearly a year with good results but they are out of stock right now.
Castle Creations used to offer some pricey but good quality brushed ESC's but all but a 7 amp have been discontinued.
I found a couple with google.
Hobbico 25 Amp http://www3.towerhobbies.com/cgi-bin...&I=LXSSH5&P=FR
E-Flite has several http://www.e-fliterc.com/PowerSystems/SpeedControllers/
You can get E-Flite through Horizon Hobby
ElectriFly has one too. http://www3.towerhobbies.com/cgi-bin...&I=LXKBF4&P=ML
Turner is offline
Old 09-17-2010, 08:58 PM
tarheal63
tarheal63's Avatar
I beleive I have one of the turnigy 30 A brushed NIB. I will look when I get home. I could send it to you cheap.
tarheal63 is offline
Old 09-17-2010, 09:00 PM
Gohmer
Banned
Default ESC
I have some of these, work well.
http://www.rchotdeals.com/Products/r...rs/BAS30C.html
Gohmer is offline
Old 09-17-2010, 10:37 PM
deltbro
Tarheal63, let me know, I am interested! Thank you!
deltbro is offline
Old 09-18-2010, 02:39 PM
deltbro
I am interested, let me know if you can find the ESC!
deltbro is offline
Old 09-18-2010, 02:53 PM
smokejohnson
smokejohnson's Avatar
This is what I use in my SuperCub with a stock motor, 1300mah 3S lipo, and an AR500 rx. I'm using a couple of Hitec HS55 servos.
smokejohnson is offline
Old 09-19-2010, 04:41 AM
philipa_240sx
Brushed ESC's are becoming more rare everyday.
That Blue Arrow Gohmer linked to has one of the better LVC's (3v/cell) that I have seen on any of them. If you can find one, go for it.
philipa_240sx is offline
Old 09-19-2010, 02:36 PM
philipa_240sx
Or you might seriously consider going brushless altogether....
The hard part is fabricating a motor mount. You can buy retrofit mounts now, but they don't come cheap. HeadsUPRC has one:
http://www.headsuprc.com/servlet/the...unt/Categories
It appears to be the CustomRC CNC'd aluminum mount:
http://www.customrcparts.com/motorMo...15&&bannerID=2
Old 09-19-2010, 06:20 PM
flydiver
flydiver's Avatar
There are 2 nasty shortcomings to most brushed ESC > the LVC is often permanently set to NiMh and destructively low, and the BEC is usually only 1A or less.
Be sure to read and understand the specs. No specs - don't buy.
If you upgrade the Cub to ailerons and put 4 servos in there you may be creating a recipe for BEC failure, especially with amp hungry servos (HXT 900) and Spectrum (brown out).
flydiver is offline
Outacontrol
02-08-2010 05:26 AM
Balsa Shavings
ParkFlyers
32
04-07-2009 09:24 PM
retiredbri
ParkFlyers
12
10-18-2008 11:06 PM
jnastasi
ParkFlyers
10
09-13-2007 06:57 PM
Daz1701
02-03-2007 08:44 PM
Quick Reply: Replacement ESC for HZ SuperCub
Page generated in 0.07643 seconds with 13 queries
