new at the 2.4 Ghz transmitter's and receivers
Old 11-12-2021, 11:26 PM
Rhondas
Rhondas's Avatar
Default new at the 2.4 Ghz transmitter's and receivers
I just was given B17 fortress very small scale with a blade 2.4 MHz channel transmitter and it has the AS3X stability .
I was also given a corsair air 48 " wing with the AS3X receiver in it. will the simple Blade transmitter work with this larger model or the range wouldn't be enough .do they make a Receiver 72 MHZ with AS3X added to it or can I purchase a isolated AS3X to plug into the 72 MHz receiver?
Name:	MLP4DSM 4 CH TRANS 2.4 GHZ BMCX2,120R BLADE.JPG
ID:	188599   Click image for larger version
ID:	188600   Click image for larger version
Rhondas is offline
Old 11-20-2021, 09:23 PM
It is hard to say definitively since there are no specs listed for that transmitter but having been around this for a while I'm going to say no. I just don't see it having the range to be effective with a larger bird like that
Old 11-22-2021, 11:02 PM
I think both of those will work with Spektrum transmitters like a DX6 or the others offered by Spektrum.
Page generated in 0.10531 seconds with 18 queries
