shuttle scratch build - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-12-2005, 09:10 PM
ericthetree
ericthetree's Avatar
Default shuttle scratch build
I won't know if it flys until I get my motor to run WOT
Name:	handy razor with quick change 038 (WinCE).jpg
ID:	2518   Click image for larger version
Name:	handy razor with quick change 039 (WinCE).jpg
ID:	2519   Click image for larger version
Name:	handy razor with quick change 047 (WinCE).jpg
ID:	2521   Click image for larger version
Name:	handy razor with quick change 049 (WinCE).jpg
ID:	2522   Click image for larger version
Name:	handy razor with quick change 050 (WinCE).jpg
ericthetree is offline
Old 10-12-2005, 10:30 PM
vicman
Carolina Crew Ambassador
vicman's Avatar
I think you will need a bigger vertical. Otherwise very cool!
vicman is offline
Old 10-12-2005, 11:13 PM
ericthetree
Default how's this?
increased 60%
Name:	handy razor with quick change 051 (WinCE).jpg
Old 10-12-2005, 11:24 PM
vicman
vicman's Avatar
That was quick! Yep looks alot more like it should. I will snap a pick of mine later tonight.
vicman is offline
Old 10-12-2005, 11:42 PM
ericthetree
am interested in seeing your's
Old 10-12-2005, 11:48 PM
StephenT
3D and P's Dad
I want to see it fly!!!
StephenT is offline
Old 10-13-2005, 01:05 AM
ericthetree
Default shuttle
not as much as I do! lol
Old 10-13-2005, 03:36 AM
vicman
vicman's Avatar
Here they are unfortunately they are rocket powered.:o
Eric, what type of power plant are you going with?
ID:	2533   Click image for larger version
vicman is offline
Old 10-13-2005, 04:17 AM
ericthetree
I'm using a 5400kv bl with 3cell lipo swinging 4 5/16 x 5 prop,trying to figure out what to buy as power source. Your's are much more to scale, NICE.
Old 10-13-2005, 05:01 PM
E-Challenged
E-Challenged's Avatar
I think it'll fly after you get the elevator or elevon up/down trim set right. Not sure about stability in turns. Maybe it would be wise to build a balsa sheet or foam glider version and tweak the control surfaces to get an idea how it will glide straight ahead and in turns. The real one doesn't do much but fly like a high speed flatiron and make gradual turns.
E-Challenged is offline
Old 10-13-2005, 08:10 PM
ericthetree
if it just gets off the ground and flies I'll be happy,it's not meant to be a stunt plane. I think it will need a long runway, the steerable nose gear will help.
Name:	handy razor with quick change 054.jpg
Old 10-17-2005, 04:41 AM
ericthetree
Default latest pic
still have to mount servos, then i can button up side.auw should be about 11oz.
Name:	handy razor with quick change 069 (WinCE) (2).jpg
ID:	2742   Click image for larger version
Name:	handy razor with quick change 070 (WinCE).jpg
Old 10-17-2005, 05:23 AM
nakelp86
nakelp86's Avatar
Default Blue foam wing
Looking for place or anyone who will cut 60" blue foam wing (two pannels 30")
nakelp86 is offline
Old 10-21-2005, 01:59 PM
gyronuts
How about this one. Bell brushless motor, 3 s 2000 lipoly and gws 8 x 6 prop. Bill
It will loop but not very well, rolls nicely ,flies on rudder alone ,elevons very powerful. Does NOT like inverted, after 4 secs tumbles all over the place and needs 100ft to recover!!!!
ID:	2915   Click image for larger version
ID:	2916   Click image for larger version
ID:	2917   Click image for larger version
gyronuts is offline
Old 10-21-2005, 03:43 PM
ericthetree
why does it tumble?
Old 10-23-2005, 06:28 PM
gyronuts
I think that the fuselage is so massive that any yaw has such an effect and the model so light that it takes some time to end up going downwards and producing lift again,Perhaps!!! Bill
gyronuts is offline
Old 10-23-2005, 07:26 PM
ericthetree
what is your LOA, mine is only26" and span is 24"
Old 10-23-2005, 08:49 PM
gyronuts
Length..36"
Span ...26" flat sheet 3 mm depron
weight without battery...25oz
Battery one....3s1500 kokam...4.1oz
Battery two....welgrade 3s2000 ..5.7 oz.
Bill
ID:	3013   Click image for larger version
ID:	3014   Click image for larger version
ID:	3015   Click image for larger version
gyronuts is offline
Old 10-23-2005, 10:15 PM
ericthetree
looks like we have similar tastes in planes lol
Old 10-23-2005, 11:25 PM
gyronuts
So I see. Bill
Some of my models.
Fizza, flying flea, Ornithopter, PT Gyro, Pushy cat
ID:	3023   Click image for larger version
ID:	3024   Click image for larger version
ID:	3025   Click image for larger version
ID:	3026   Click image for larger version
gyronuts is offline
Old 10-24-2005, 10:06 PM
vicman
vicman's Avatar
I like that Pushy Cat.
vicman is offline
Old 10-24-2005, 11:20 PM
gyronuts
Yes the Pushy cat is from a free plan, Jan QEFI ,I think.
I have had three. Still have no 2 and no 3. All fitted with a brushless typhoon 15 and 3s lipoly. Launches underarm easily and is SO SMOOTH. Bill
ID:	3039   Click image for larger version
ID:	3040   Click image for larger version
ID:	3041   Click image for larger version
gyronuts is offline
Old 10-25-2005, 03:58 AM
vicman
vicman's Avatar
Pm
vicman is offline
Old 10-25-2005, 04:31 AM
nakelp86
nakelp86's Avatar
thx guys for help
nakelp86 is offline
Old 10-28-2005, 10:53 PM
ericthetree
shuttle flies nice, here is my next project
Name:	handy razor with quick change 075 (Small) (WinCE).jpg
ID:	3190   Click image for larger version
Name:	handy razor with quick change 076 (WinCE).jpg
Quick Reply: shuttle scratch build
Page generated in 0.12874 seconds with 45 queries
