15e RX issue with the apprentice?
Old 09-27-2022, 03:22 AM
WadeWarner
Default 15e RX issue with the apprentice?
I took the wing off and switched the switch on, but nothing occurred. I had the plane out a week earlier and had a typical flight day; I put it away, and now it isn't working. The rudder moved a tiny bit when I flipped the on/off switch on the plane, but other than that, nothing happened. When I avoided the switch, the same result would occur. What might be causing this?
WadeWarner is offline
Old 09-27-2022, 09:17 PM
The switch does not switch battery power off (the switch would have to be big/heavy.)
Always remove battery after a days flying.
The ESC still draws some current with switch turned off, thus ruining your battery.
Page generated in 0.07170 seconds with 11 queries
