Blade MCX Flybar
Old 12-01-2008, 05:10 PM
mjack777
Stay classy, planet Earth
mjack777's Avatar
Default Blade MCX Flybar
Been flying my new Blade MCX all week with only 1 minor problem.
I kept getting my lipo stuck in the charger,seen one battery come apart from
being pulled out of the charger....so I just made some mods to the charger...
Anyways
Im looking at some stock pics, and I noticed the flybar is different than the one I have. Mine has no profile to it, and is essentially a weighted tube.
Any thoughts?
mjack777 is offline
Old 12-01-2008, 05:49 PM
gfdengine204
gfdengine204's Avatar
Anyways
Any thoughts?
Mike,
Care to elaborate on the modifications you did? Maybe post some pics?
As for the flybar, perhaps an email to Horizon would be in order. They may have modified the flybar during initial production.
gfdengine204 is offline
Old 12-01-2008, 07:51 PM
mjack777
mjack777's Avatar
Default charger mod
I would post some pics, however Im stuck here at work with my "Dino-PC" that does not have a usb port.
Basically, I removed all 4 screws from the charger. (under the foot pads)
I removed the LED from the opening of the charger, and relocated it to the
bottom of the charger. I removed the two screws for the connector/plug base. I taped down the wire and wrapped the small printed board with
electrical tape to protect the pos and neg connections.
I reassembled the two halves of the charger and using a piece of electrical tape, made a hinge on the left side of the charger. It now opens like a book. And when you open it, you find your battery lying right in the front section
of the charger base. Connects/disconnects easily and away you go.
M
mjack777 is offline
Old 12-01-2008, 11:01 PM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
Geez......too much like work!!
just use a very small screwdriver or a dull hobby knife to gently start the battery
up from the charging jack.
Heli Jim is offline
Old 12-06-2008, 04:55 AM
DaveESPI
use a dremel tool and cut a small notch in the battery plastic adapter, and then use a NON METALIC TIPPED screwdriver ( Like a radio knob adjustment one) to rempove the battery from the charger.
* A metal tip can potentialy cause a direct short and the lipo to catch fire.
DaveESPI is offline
Old 12-23-2008, 09:19 PM
fatcatzzz
I have the same problem with the batt. I took some a small jewlers file to the inside of the charger, also put a small piece of tape on the battery, it is easier to pull on the tape than the top of the battery.
fatcatzzz
fatcatzzz is offline
Old 12-23-2008, 09:37 PM
rcflyair
Default mcx charger
I have the same trouble (fat fingers).
I got some of the Tenergy 130mah's yesterday with the little tape pull tab on the end. They're great, but come dangerously close to hitting the servo gears when you get the battery in the heli.
I was considering putting a bit of tape on the E-Flite battery, but its beginning to whimp out. I only have about 30 flights on it, but I've seen posts that say they're not lasting very long.
I don't care for the connetors they've used, and me thinks the charger is too "hot" for those little batteries.....
rcflyair is offline
Old 12-24-2008, 04:30 PM
Ron S
Ron S's Avatar
Location: Lawrenceville,(in the middle of nowhere) Illinois
Anyways
Any thoughts?
The "profiled" flybar was a "first run" flybar. Horizon has since went with the cylinder shaped weights on the flybar. There is no diffrence in performance. I've got both! One looks like little fat paddels,the other one looks like little "tootsie rolls" ,both fly the same. Ron
Ron S is offline
Old 12-25-2008, 07:36 PM
miru
Had the same problem with the charger.... Took the circuit board out of a toasted styrofoam helicopter (it uses the same connector), gutted the electronics and soldered a JST connector to it. Now I can use my Thunderpower charger to recharge those little buggers. Works great and I can see how much the battery gets recharged. I learned the hard way, that if you ever discharge it over 90 mAh it goes south in a hurry, so from now on out I keep my flight times at 5 minutes.
miru is offline
Old 01-03-2009, 05:42 AM
dlehman
Hmm... weird. If there is no performance difference, do you know why they changed the flybar weight profile? Maybe a manufacturing issue?
dlehman is offline
Old 01-03-2009, 12:21 PM
Ron S
Ron S's Avatar
Yes! It is much easier/faster,to produce,and attach the "round" weights than the paddel shaped ones. I have a set of both,and can tell you,there is no diffrence in performance. Infact mine seems to respond quicker with the round one's installed. Ron
Ron S is offline
Old 01-03-2009, 07:14 PM
wbrosen
To get the batteries out of the charger just put a tape tab at the rear. It makes it easy to grab and pull out. The Tenergy replacements have the tab on them. http://www.ritehobby.com/
wbrosen is offline
PsychoKory
E-Flite Helicopters
11
12-20-2008 02:39 AM
Old Blade Man
E-Flite Helicopters
11
11-14-2008 07:29 PM
rdr4evr69
11-11-2008 07:01 PM
Drake
Beginners - Helis
04-15-2007 03:27 AM
Quick Reply: Blade MCX Flybar
Page generated in 0.11299 seconds with 13 queries
