Composite Warbird Build 1/7th P-40E Warhawk - Page 10 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 01-13-2013, 04:47 PM
  #226
Slow & Low
b1heqh54
Slow & Low's Avatar
Slow & Low is offline
Old 05-21-2013, 03:57 PM
  #227
Slow & Low
b1heqh54
Slow & Low's Avatar
So strong they’re scary and so light it makes you look twice when you pick one up…
Al/GRP Laminated D-box Leading Edges
Old 05-22-2013, 04:52 PM
  #228
Slow & Low
b1heqh54
Slow & Low's Avatar
Less is more....
Old 05-23-2013, 02:53 PM
  #229
Slow & Low
b1heqh54
Slow & Low's Avatar
Old 05-24-2013, 10:04 PM
  #230
Slow & Low
b1heqh54
Slow & Low's Avatar
Crude initial hand layup 410 grams or 14.5 Ounces or 0.9 lb
Part looks great. Still stiffening up a bit.
Old 02-18-2014, 10:48 PM
  #231
Slow & Low
b1heqh54
Slow & Low's Avatar
Year Six I think ??
Clear packing tape is not very good in compression but applied around the periphery like this it works very well in shear.
There are no internals here. By taping this up for a quick touchy-feely session, it should be quickly apparent that little internal structure is required at this scale. The inherent beam strength of the cast trailing edges coupled with the rigidity cast into the lower skin by including the wheel and flap bay details yields an empty shell that is almost strong enough without internals. Very promising, not to mention motivating and satisfying to stare at...
[a href="http://s1069.photobucket.com/user/Two_Bulldog/media/P82000012_zpsfc4ad5fa.jpg.html"][img src="http://i1069.photobucket.com/albums/u475/Two_Bulldog/P82000012_zpsfc4ad5fa.jpg" style="max-width:100%;"][/a]
Old 03-05-2014, 08:35 PM
  #232
Slow & Low
b1heqh54
Slow & Low's Avatar
I couldn't find my old homemade hotwire cutter. (an old battery charger, a block of wood, two copper pipes, and a guitar string worked just fine for many moons...)
This is a small investment that will save many, many, hours of cutting balsa ribs, or paying for the laser cutting etc...
I have to say, it's a beautiful little tool that I should've bought 30 years ago.
The wires it uses can be bent to shape. A small Vee profile around the perimeter of a rib might do well to hold the cabosil/milled fibre goo in place during assembly.
What you see in the photos is the aluminum cutting template in white and the foam rib in blue.
I first printed paper templates to scale and later transfered the paper template to the aluminum shown here.
Here's a tip - check your yellow pages for custom eavestrough - they buy aluminum sheet stock by the roll...
Proxxon Tools, Hotwire Cutter Thermocut 12/E (12v DC)
Voltage
12v, 60w, 50/60Hz
Cutting Wire Temperature
300 - 660 ºF
(150 - 350 ºC)
Maximum Extension
7.9" (200mm)
Cutting Height
5-3/4" (150mm)
Wire (NiCr8020)
11.4" Long, 20 gauge
Weight
0 lbs (3.0kg)
Warbird Electrics
185
04-23-2009 06:20 AM
lz23
Warbird Electrics
25
04-11-2008 04:15 AM
Slow & Low
Video Parking lot
03-30-2008 02:33 AM
lz23
Warbird Electrics
01-31-2008 10:42 PM
K CLOSE
Warbird Electrics
8
04-12-2007 09:11 AM
Quick Reply: Composite Warbird Build 1/7th P-40E Warhawk
Page generated in 0.09868 seconds with 14 queries
