"Five Easy Piece" Dassault Rafale - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 10-12-2014, 05:02 AM
Bobdaeronort
Bobdaeronort
Default "Five Easy Piece" Dassault Rafale
Got a chance to work on the Rafale pattern today. This is just the first mock-up. The canopy and dorsal structure is out of place just now. Next is the dorsal panel so the canopy and upper fuse pieces will notch into the dorsal panel. Looks like she's 44" long overall from tail fin to nose. Thirty-two inch Delta wingspan.
Name:	Rafale Patt@9 .jpg
ID:	177805   Click image for larger version
Name:	Rafale patt @10.jpg
ID:	177806   Click image for larger version
Name:	Rafale patt@11 intakes & Canard.jpg
ID:	177807   Click image for larger version
Name:	Rafale patt forward fuse shape intakes canards.jpg
ID:	177808   Click image for larger version
Name:	RAFALE IMAGES.jpg
Bobdaeronort is offline
Old 10-12-2014, 06:39 AM
That is looking Great keep up the nice work, Chellie
Old 10-12-2014, 03:24 PM
Bobdaeronort
Bobdaeronort
Thanks Chellie.
Check out my completed Su-34 Fullback and her maiden flight here:
http://www.wattflyer.com/forums/show...t=67322&page=2
Old 10-13-2014, 03:47 AM
Bobdaeronort
Bobdaeronort
The "Five Easy Piece" Dassault Rafale rendered in foam.
ID:	177878   Click image for larger version
ID:	177879   Click image for larger version
ID:	177880   Click image for larger version
Old 10-13-2014, 09:36 PM
Bobdaeronort
Bobdaeronort
Continuing to modify the Rafale to increase the frontal exposure of the propeller so as not to starve it for air. I use a disk with a 6.5" diameter to check prop clearance.
Name:	Rafale @3 w prop-disk.jpg
ID:	177888   Click image for larger version
Name:	Rafale@11 w prop-disk.jpg
ID:	177889   Click image for larger version
Name:	Rafale @12 w prop-disk.jpg
Old 10-15-2014, 12:29 AM
Bobdaeronort
Bobdaeronort
Changed the fuse to a Rafale B two seater.
Name:	RAFALE B @ 3.jpg
ID:	177904   Click image for larger version
Name:	RAFALE B @ 10L.jpg
ID:	177905   Click image for larger version
Name:	RAFALE B @12H.jpg
Old 10-15-2014, 01:03 AM
Its getting there Looking good Bob, Try building with white depron 6 mm and 9 mm Foam, the blue cor foam is Ok, but the Depron is much stiffer, and will give you a super nice build, the blue cor foam tends to wafer when building, where the depron stays nice and Flat. try using 5 and 30 min epoxy too, I buy epoxy from Harbor freight tools, it works great and does not turn yellow. Before I Forget Wipe the Depron with Rubbing alcohol, that will remove the release agent that is used when making the foam, and tape and paint will stick better to the foam.
https://www.rcfoam.com/depron-and-ep...0e2d3eae33539f
http://www.harborfreight.com/uick-se...oxy-68386.html
Old 10-15-2014, 04:06 AM
Bobdaeronort
Bobdaeronort
[/URL]
OUCH!
I checked out the white Depron prices. Way to rich for me. I smash them too much and too often to afford the nice stuff.
I built my "5EZP" F-18C with some white Depron from Grayson Hobby. It was pretty nice foam. But also too expensive.
Also my short attention span and need for immediate gratification makes using epoxy impossible. So I guess it's still hot glue and burnt fingers for me.
Dow blue-core can be wavy but the Owens-Corning Pink fan-fold is flat and around here it's also cheaper.
I'll have to try the alcohol treatment. Thanks.
Old 10-17-2014, 04:07 AM
Bobdaeronort
Bobdaeronort
Got in the truck to head to the field to maiden the "Five Easy Piece" (X2) Rafale and the truck won't start. Plenty crank but no fire. So maybe tomorrow. Better weather tomorrow anyway.
Old 10-18-2014, 09:04 PM
Bobdaeronort
Bobdaeronort
"5EZP\2" Dassault Rafale https://www.youtube.com/watch?v=6q-8FhzZzCE
Old 10-18-2014, 09:09 PM
I hate that when that happens what type of truck do you have, Also the video does not seem to work
Old 10-19-2014, 03:07 AM
Bobdaeronort
Bobdaeronort
I have a Ford F-150 Quad-cab / short bed. Turned out to be the OEM security system relay and fuel pump relay.
Sorry bout that, Try this one:
Old 10-19-2014, 03:10 AM
Glad it was a easy and cheap Fix Your plane flies good, Looks to need more thrust, Try a 7X6 APC Prop, that should really wake it up
http://www.graysonhobby.com/catalog/...reviews_id=860
GH Super Mega Jet V2 Brushless Outrunner Motor
[SuperMegaJet] $34.99 by Marbris Dillard Date Added: Monday 03 March, 2014 All I can say is OMG! This motor pushed my dollar tree foam board scratch build to 94 mph, logged on a voltron GPS logger. I have been flying the supersonic motor which flew my plane very well on a 6x5.5 apc e. But this smjv2 is a whole other animal! Vertical is unlimited, and turns a 7x5 prop all day with no heating problems at all. My setup is smjv2, 3S 2200 30C lipo, detrum 60 amp esc. I have never tried a 4S with this motor, and honestly I have no intention to at this point lol. Flight time is 5-7 minutes. This motor is awesome. I ordered the monsterjet to test 4S on my next scratch build. Plane weight is 21 oz full flying weight. Only issue is I have to be careful pulling up to hard cause the thrust is very hard on my wings even with reinforcement and kfm4 airfoils.
Old 10-19-2014, 04:40 AM
Bobdaeronort
Bobdaeronort
Thanks!
Well cheaper than a fuel pump.
I was flying her at half throttle and sometimes just 1/3 throttle trying to find her stall speed (I guess you noticed the wing rock) so as to test it and to extend the flight time. Still she cruised around just under 50 mph per RCSPEEDO @ 1/2 stick.
The Rafale's flying weight is 23 oz. The SMJv2 with a 6x4 puts out about 30 oz.
so that's a 1.3 thrust to weight ratio which ain't toooo bad.
I've used a 7x5 on this motor before but that's too big for the Rafale's prop-slot. So I will mount a 6x5 APC instead for the next flight. I used the SMJv2 with a 6x5.5 on my "5EZP" F-18E Super Hornet to great effect in 2012.
I may build an EDF version with a 70mm on 4S power. That's 40+oz. of thrust.
Old 10-19-2014, 05:17 AM
Hi Bob If You Build the EDF Version, Join in on the EDF Build contest, would love to have you on board or Scratch build anything with a EDF
http://www.wattflyer.com/forums/showthread.php?t=74592
Old 10-19-2014, 02:44 PM
Bobdaeronort
Bobdaeronort
OK. I'm in with my "Five Easy Piece x2" 70mm EDF Rafale B.
Chellie you're gonna get me in so much trouble. LOL.
Old 10-27-2014, 03:48 AM
Bobdaeronort
Bobdaeronort
The new Rafale B pattern cut-out and taped together less the fuse cap and pan on the side.
Name:	5EZP Rafale B pattern 10.26.14 .JPG
Old 10-27-2014, 04:33 AM
Trouble is My Middle name Its no Fun if your not getting into a little trouble now and then
Old 04-30-2015, 04:26 AM
Bobdaeronort
Bobdaeronort
Ok I finally got round to building the RAFALE again after a long hiatus.
Name:	Dassault RAFALE @ 3.JPG
Old 05-01-2015, 03:03 AM
Bobdaeronort
Bobdaeronort
RAFALE DIALING
https://www.youtube.com/watch?v=LlZBYA8nxFs
Old 05-07-2015, 02:14 PM
Bobdaeronort
Bobdaeronort
https://www.youtube.com/watch?v=d9cTDXLmjmQ
Bobdaeronort
Bobdaeronort
https://www.youtube.com/watch?v=RU3XMA1R-Nk
Old 06-06-2019, 10:24 AM
swissflying
Default plan available?
any plan in pdf?
swissflying is offline
Bobdaeronort
Pusher Park Jets
75
11-29-2019 12:56 AM
Bobdaeronort
Pusher Park Jets
29
10-25-2019 02:39 AM
Bobdaeronort
Pusher Park Jets
29
10-20-2019 02:41 PM
Bobdaeronort
Pusher Park Jets
17
10-09-2019 12:53 PM
Bobdaeronort
Pusher Park Jets
35
12-27-2013 04:31 AM
Quick Reply: "Five Easy Piece" Dassault Rafale
Page generated in 0.13962 seconds with 29 queries
