$50.00 Scratch Build Contest Entry, F-20 Tigershark - Page 3 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-25-2013, 05:15 PM
Might just have to get the ARF version- LOL
Old 09-25-2013, 06:31 PM
Thats very nice nice pic, that will help me with my build
Old 09-25-2013, 06:35 PM
Here's some more, Chellie:http://www.motionrc.com/great-planes...m-edf-jet-rxr/
Old 09-25-2013, 06:43 PM
Sales promo film: http://youtu.be/6BDgQwlfHII
Wet turbine RC version: http://youtu.be/Scsl2hQYboM
F-20 Tribute: http://youtu.be/z7696YGqBMo
Enjoy !
Old 09-28-2013, 05:36 AM
Ok, Got those Pesky air intakes done, That was a PITA 1st attempt failed with 2mm depron, I came up with another Idea, use 9mm depron top and bottom, and 6mm on the sides and sand the curve in to it, It came out ok, now to cut out the canopy opening and make a plastic bubble to go over it, Its almost done Take care, Chellie
ID:	171156   Click image for larger version
ID:	171157   Click image for larger version
ID:	171158   Click image for larger version
ID:	171159   Click image for larger version
Old 09-28-2013, 07:08 AM
Looking good, Chellie! It looks like you'll have a working rudder, too? What about landing gear?
A sort of OT question, in that F-20 tribute video, does anyone know where to find that song? I've downloaded the one linked at YouTube, and another, and they are just like the slow part of the song that goes on and on and never gets anywhere...
Old 09-28-2013, 07:21 AM
Thank You yes, it will have a working rudder too, i want to do Knife Edges with it the landing gear will be fixed, i was going to use retracts, but i did not have the money for them, Sooooo it will get some Custom Chellie Gear, i am going to make some LG out of 1/8" x 1/2" aluminum stock and use some 2 1/4" inch wheels on the rear, the front landing gear is already in-place, I am not sure about the Music in the Vid Take care, Chellie
Old 09-28-2013, 07:22 AM
Ok, Now i have to do the canopy, Wish me luck
Old 09-28-2013, 09:19 AM
I keep an eye out for smaller, thinner wheels for my EDF's. They're fine on the paved and (mostly) hard packed dirt runways I fly from. And I hope it's a little less drag than the fat stock wheels they came with! You'll need all the help you can get for that race! And yes, good luck with the canopy! If nothing else, I guess you could just make a foam one with blacked out windows.
Old 09-28-2013, 09:24 AM
From the looks of it, i think a soda bottle will work, I have a bunch of plastic bottles around here so it should not be to hard to find something that will work, I cant belive all the Spammers we are getting right now, I just keep reporting them, and the mods nail them, wattflyers needs to get a bot killer, that will help to keep computer generated spam away,
Old 10-01-2013, 12:15 AM
I was looking for a plastic bottle to make a canopy With, I searched High and low and could not find one, so I turned my Attention to EBay, and found a canopy that I can make work for me, and it was only $7.99 , i was going to try to make a plug and use a soda bottle and heat shrink it onto the plug, but i have never done that before, and it looked like it was going to be a ton of work, $7.99 looked more attractive to me LOL
The canopy is 13" long, perfect because I need a 10 1/4" long canopy and i will have to trim it down a bit anyway, and it looks to have the perfect radius on top in the middle.
ID:	171203   Click image for larger version
ID:	171204   Click image for larger version
ID:	171205   Click image for larger version
Old 10-01-2013, 12:24 AM
Crashalott
Crashalott's Avatar
Really looking good Chellie
Nice find on the Canopy
That should do the trick.
Sorry, i won't be able to do the maiden for ya cause i don't have enough room here.
Crash
Crashalott is offline
Old 10-01-2013, 12:27 AM
  #63
Thank You Crash Now I can Work on the LG and Motor mount while the canopy comes in the mail, Take care, Chellie
Old 10-02-2013, 07:54 AM
  #64
Hi I made some Custom Chelliegear LG for my F-20 out of 1/2" x 1/8" aluminium flat stock, they came out nice and mounted them to the jet, its getting there little by little, here are some pics, Take care, Chellie
ID:	171226   Click image for larger version
ID:	171227   Click image for larger version
ID:	171228   Click image for larger version
Old 10-02-2013, 11:45 AM
  #65
Crashalott
Crashalott's Avatar
Looks good Chellie, but i am wondering how is the nose wheel fastened?
I hope it works ok for ya!
Crash
Old 10-02-2013, 12:11 PM
  #66
Crash
Hi Crash I epoxied 2 pieces of ply on the ruler, drilled a hole through the wood, on the bottom of the front gear, i put a metal collar and washer and the top is held with the arm assy that has a set screw, i ground a flat spot on the shaft where the set screw touches the shaft and used red locktite, its stronger than the plastic LG housing.
Old 10-02-2013, 12:28 PM
  #67
I was looking for some white 1" F-20 Tigershark stickers and 2" white F-20 stickers and could not find any, Sooooooooo i went to EBay and on the web, and I am Having some stickers made up for me its not to expensive to have custom stickers made up, and the white letters and numbers will show up nice against a dark grey airframe,
Old 10-02-2013, 02:32 PM
  #68
Very nice.
Is there sufficient ground clearance for the prop?
quorneng is online now
Old 10-02-2013, 10:39 PM
  #69
Originally Posted by quorneng View Post
Very nice.
I Hope So I am going to have to cut my 8" prop down to a 7" to give myself 1 1/2" of ground clearance, and that will still be cutting it close I may have to move the motor up a little from centre, I would like to have 2" of ground clearance.
Old 10-03-2013, 07:03 AM
  #70
Smile Sweet
Now, This is Sweet
[media]http://www.youtube.com/watch?v=qFZwfCYOx6s[/media]
Old 10-03-2013, 09:11 AM
  #71
>Sigh!< Those turbines sure sound nice! What a great performing plane.
Old 10-03-2013, 09:39 AM
  #72
I Know huh I Love that sound we have to use a edf with 10 or 12 blades to even get close to that sound, that was one of the reasons for wanting a edf fan blade with a ring on it to get even close to that sound. I have been doing a little research and found a 90mm fan blade and a 90mm speedi sleeve my 1600kw motor only has a 4mm motor shaft and I need a 5mm shaft motor Oh well I will have to buy a 5mm shaft motor later on I can use a 70mm fan blade with a 4mm shaft motor, but a 70mm blade wont be big enough, because i know i am going to loose some performance from not using a shroud, any way its an Idea that I am looking into, Take care, Chellie
http://www.hobbyking.com/hobbyking/s...FeV0QgodMnwAyQ
90mm 12 blade edf Fan Blade
http://www.autopartsandstuff.com/skf...di-sleeve.aspx
90mm stainless steel sleeve
Old 10-03-2013, 11:07 AM
  #73
I put the rudder on with CA hinges and 5 min Epoxy and ordered some Battle Ship Dark Grey Testors Enamel spray paint from my Favorite place to shop, EBay I dont have to drive around to get my Supplies, I just order everything I need saves me on Gas here are a few more pics, I have to make a cowl and mount the motor next, Excuse My Messy Bedroom, I got chased out of my Hobby room, My Grand kids are Living with Me for Now and My Hobby room has been taken over by them in
the big Box by the curtains, Lies a Giant P-51 Mustang Take care, Chellie
ID:	171266   Click image for larger version
ID:	171267   Click image for larger version
ID:	171268   Click image for larger version
Old 10-06-2013, 10:15 AM
  #74
Hi Everyone I Got a little more done today, I made the hatch opening a little wider, made a balsa hatch and saddle, and started to cut the plastic canopy to fit the balsa hatch cover, Its getting there its starting to look like a jet now The hatch will have 2 small dowels on the front and a very strong magnet on the rear to hold it in place with, it will need very strong magnets doing 150 MPH to hold the canopy down with Ok maybe 100 MPH, here are some pics of the progress, Take care, Chellie
ID:	171298   Click image for larger version
ID:	171299   Click image for larger version
ID:	171300   Click image for larger version
ID:	171301   Click image for larger version
ID:	171303   Click image for larger version
Old 10-06-2013, 10:23 AM
  #75
I need to go to the toy store and find a pilot, Hmmmm maybe E Bay Might have one, Got to check them out lets see whats left to do, mount motor,drink a Miller Lite, make cowel, Drink another Miller lite, paint jet,Drink another Miller lite, add decals, Drink another Miller lite, install servos, Drink another Miller lite you can see why I dont build very Fast Now days Take care, Chellie
Quick Reply: $50.00 Scratch Build Contest Entry, F-20 Tigershark
Page generated in 0.15803 seconds with 36 queries
