3D planes for 6s1p 5000 size packs?
Old 01-11-2009, 11:19 PM
Fast Guy
Out flying the other day. A couple pics.
ID:	90097   Click image for larger version
ID:	90098   Click image for larger version
Fast Guy is offline
Old 01-11-2009, 11:27 PM
Rolling Thunder
Keep the sunny side up
Rolling Thunder's Avatar
wow your plane looks sweeeeet on skis with the backdrop of the snow & clouds.how well do your skis work when landing....again sweeeeet!!!
Rolling Thunder is offline
Old 01-12-2009, 12:01 AM
PropSpinner
PropSpinner's Avatar
Default skis
I assume those are Dubro skis. Is that a park flyer ski on the tail?
PropSpinner is offline
Old 01-12-2009, 02:41 AM
Fast Guy
I like landing on skis and snow better than on grass. Skis work very well on landing except the plane takes about 100ft. to glide to a stop.
Fast Guy is offline
Old 01-12-2009, 02:44 AM
Fast Guy
Right on both counts. Steers very well on snow with the park flyer.
Fast Guy is offline
Old 01-13-2009, 04:09 AM
EDFrules
GravesRC enabler d:)
EDFrules's Avatar
How do the skis affect 3D, if at all?
EDFrules is offline
Old 01-13-2009, 11:03 AM
Fast Guy
Skis add a little weight and a bit of a flight surface. On the Sukhoi 50e it is hardly noticeable. 3D as normal. Plane has crazy vertical in the heavier winter air. Maybe a little more floaty on horizontal flight and landing.
Fast Guy is offline
Old 02-07-2009, 07:36 PM
alchemique
alchemique's Avatar
SU 50e is far to big for 6s 5000 setup. You may try SU 140 from sebart with axi 5320/18 and 10x8 prop and 6s 5000. It will be a true floater. Gernot Bruckmann uses this setup in aeromusical competitions.
alchemique is offline
Old 02-07-2009, 07:42 PM
EDFrules
EDFrules's Avatar
Look for SEFF this year. 3DHS is unveiling a 70" 3D plane this year. Designed for 6s 5000 packs. Should be sweet! I'm hoping they do a 70" version of the Vyper-awesome! Just what I'm looking for.
Jason
EDFrules is offline
Old 02-07-2009, 07:48 PM
alchemique
alchemique's Avatar
Yes, 70' from 3DHS might be a solution, you can also wait for EF Extra 78'. I'm sure if you keep it light you will not be dissapointed.
Just take a look at this vid - http://video.google.pl/videoplay?doc...C4qzDCw&q=hepf
Old 02-07-2009, 08:38 PM
EDFrules
EDFrules's Avatar
Seen Gernot fly that one before. Those packs have to be smokin'! My full fuse Bipe-X proto is designed for 6s packs and I'm trying to keep it lite for just the same reasons-should be fun!
Jason
EDFrules is offline
Old 02-13-2009, 12:03 AM
PropSpinner
Well, I'll find out in the Spring. I built a SU 50E with 6 cells this Winter.
Old 07-08-2009, 03:59 AM
  #63
PropSpinner
Default It flies
It flies.
Old 07-08-2009, 11:36 AM
  #64
Fast Guy
PropSpinner, how do you like it? What did you end up using for motor, ESC and prop. Between my son and I we are starting to get quite a collection of planes and the Sebart is still our best flyer.
Fast Guy is offline
Old 07-10-2009, 01:21 PM
  #65
Azarr
Electric Junkie
Azarr's Avatar
Has anyone looked at the new GP Reactor Bipe. I'm considering it for a 6S setup, but none of the photos show any hatch detail.
http://www.greatplanes.com/performan.../gpma1023.html
Azarr
Azarr is offline
Old 07-10-2009, 03:30 PM
  #66
Fast Guy
Azarr
I have been looking at this one for a possible next project. Trouble with GP/EP planes is they tend to be a little heavier than the same plane designed for EP only. Down load the manual, they show the battery hatch. looks like a good design.
Fast Guy is offline
Old 07-10-2009, 11:40 PM
  #67
Azarr
Electric Junkie
Azarr's Avatar
Duhh - can't believe I didn't think of that. Thanks.
I understand the GP planes tend to be on the heavy side, but that's exactly what I'm looking for. With the gale force winds we've had all year heavy may not be bad
Azarr
Azarr is offline
Old 07-11-2009, 06:30 AM
  #68
EDFrules
EDFrules's Avatar
Looks like a perfect 6s plane is just about to hit the market. 3DHS 70" Slick is one bad ass machine. Saw it in action at SEFF flown by the designer himself-Andrew "Animal" Jesky. I got to hold it and it is light! Andrew put it thru its paces during the event, didn't look like it had any bad habits or coupling. Sweet!
http://www.rcgroups.com/forums/showthread.php?t=1043263
Name:	Aj Slick SEFF09_AF_Slick_Dusk.jpg
EDFrules is offline
Old 07-12-2009, 01:35 PM
  #69
PropSpinner
Default Setup
I went with the recommended setup.
Engine: Hacker A50-16S
ESC: X70 SBec-Pro
Battery: Flight Power
3300-6S or 3700-6S
Propeller: APC 17x8E
The only thing that's different is that I'm using flightpower Evolite 4270 6s.
Old 07-25-2009, 06:32 AM
  #70
aramsdell
aramsdell's Avatar
EDFrules, Last fall you asked if anybody was using the 6S 4900 Rhinos's. I have a 6S in my Sport Swift 16, but I fly it with a Scorpion 4025 1100kv. Thatas a 600 sized Trex motor. It is a ballistic rocket and I will be buying some more of these bats. Guess what ??? Hobbycity dropped the price under $90 !!!!!!!!
This bat balnces perfectly on my FMA BalancePro charger and it doesn't appear to have lost ANY capacity ina near 100 flights. Iknow, I accidently drained it to just under 3.0 v per cell and charged back over 5200 ma.! EagleTree has me peaking over 123 amps on heavy maneuvers.
I just ordered a few smaller Rhinos for foamies. There are a bunch of different configs in all cell counts up to 6. A 3S700 is <$10
aramsdell is offline
Old 07-26-2009, 03:07 AM
  #71
EDFrules
EDFrules's Avatar
Good to hear. I've been testing out some Flightmax's myself and also the Rhinos. No complaints yet-especially in the price dept. We're debating on whether it's worth it to carry them @gravesrc.com. HK doesn't give dealer prices, so we'd have to mark them up. My unofficial pole of customers at the store has confirmed that most would gladly pay a little more to have them on hand. Also @ SEFF, I saw more Zippys than the top brands and the performance was on the level or better. I'll be ordering some 6s 5000 30c's for my big bird and some more packs for my 450 heli. Love to have TP's in every model of mine, but I'd rather get 2 or 3 packs for the price of 1!!!!
EDFrules is offline
GreenAce92
3D Flying
25
08-19-2008 11:59 PM
rcjake
10-13-2006 09:03 AM
RSS Feed
RCU RSS Feed
08-11-2006 11:10 PM
enrique1123
05-19-2006 02:26 AM
supi7
03-28-2006 11:39 PM
Quick Reply: 3D planes for 6s1p 5000 size packs?
Page generated in 0.12464 seconds with 19 queries
