Airplanes - Electric For Sale & WTB Electric Powered RC Planes for sale and wanted in here. Free to buy or sell!
For Sale Mini Ultra Stick (Stik)
Old 04-03-2009, 01:34 AM
MedcinMn
Default Mini Ultra Stick (Stik)
It’s Spring cleaning time, therefore I’m making room. This is a lightly used Mini Ultra Stik.
Mini Ultra Stik $129.99
Park 450 $64.99
E-Flite 20A ESC $41.99
Futaba 4YF Radio with (2) Micro Servos $109.98
(2) additional micro servos $30.00
Futaba Rx
Dubro tail wheel _________________
Retail $356.94
Will sell for $250.00 shipped anywhere in the contiguous US.
MedcinMn is offline
Old 07-13-2009, 05:16 AM
zdsweet
zdsweet's Avatar
Default Would you trade for one of these?
Half Finished Electrifly MiniSlinger For Trade
FEATURES: A speedy Electrifly Mini Slinger. Includes an ElectriFly brushed motor (can be upgraded) and wing. Wing also has two carbon fiber rods for extra stability.
INCLUDES: Mini Slinger, half completed, with: An ElectriFly C-12 Micro Speed Control, 3 spare props, 2 batteries, (8 cell 9.6 volt 2/3AAA 350MAH NIMH) 2 Hitec HS55 Micro Servos, Extra carbon fiber rods, extra push rods and connectors, main motor set up, with canopy, and the wing, which has already been epoxied together, and servos put in, but not glued. Oh, and of course, the manual.
SPECS: Wingspan: 31.5 in (805 mm) Wing Area: 230 in² (24.8 dm²) Weight: 7.5-8.5 oz (213-240 g) Wing Loading: 4.7-5.3 oz/ft² (14-16 g/dm²) Length: 15 in (380 mm)
REQUIRES: Transmitter and receiver.
COMMENTS: This should be a fun plane to build and fly, and possibly modify! It is meant to be fast, so have fun with it! __________________________________________________ __________________________________________________ ______________________________
E-Flite Enticement For TRADE
FEATURES: A great flying E-Flite Enticement. The Enticement is a flat foam profile monoplane with precision and aerobatic flight characteristics. Constructed of genuine 3mm Depron foam, this attractive, easy-to-assemble flat foam model improves upon other similar designs in the market and adds the stability and strength that other models are lacking. Compared with other products on the market, the Enticement is easier to assemble, and utilizes high-quality construction and manufacturing techniques. The Enticement’s extraordinary performance is attributed the lightweight, laser-cut Depron foam construction and carbon fiber support rods and carbon fiber firewall set a new industry standard for quality, durability and performance. The optional SFGs and speed brakes facilitate extreme slow flight. This lightweight plane is capable of competition-level performance thanks in part to its unique design that eliminates flex so control response is crisp and precise. Its lightweight design is focused around E-flite’s Park 250 BL Outrunner Motor, with great power-to-weight ratio for top aerobatic performance. This indoor foamie has great stability, strength, and the right blend of characteristics to excel in precision aerobatic flight. The only problem with this plane is that it needs a new Brushless motor. If you think you can figure out what is wrong with the motor, than you have a completed plane.
INCLUDES: An E-Flite Enticement foamy with three E-Flite micro servos, a brushless motor that doesn’t work (maybe does), an Electrifly BL-12 ESC, and a ThunderPower 3 Cell 730 MAH LiPo Battery. The plane has flown twice-before the motor stopped working.
SPECS: Wingspan: 34 in (860mm) Overall Length: 33 in (833mm) Wing Area: 241 sq in (15.5 sq dm) Flying Weight: 5.0–5.75 oz (140–165 g) Motor Size: E-flite Park 250 BL Outrunner Motor, 2200Kv Prop Size: 8x4 direct drive prop: Black Speed Control : Electrifly BL-12 ESC Control Throw (Ailerons): 1.25 in (35mm) with 25% Expo on Low or 2.0 in (50mm) with 40% Expo on High Control Throw (Elevator): 1.0 in (25mm) with 20% Expo on Low or 1.5 in (40mm) with 45% Expo on High Control Throw (Rudder): 1.5 in (40mm) with 30% Expo on Low or 2.75 in (70mm) with 50% Expo on High Scale: Indoor F3P/Aerobatic Flyer
REQUIRES: A LiPo battery charger, possibly a new motor, and a Transmitter and Receiver.
COMMENTS: This Spectra has been flown two times by me. It is in excellent condition except for a possibly irreparable motor. Overall this plane flies excellent, and I would recommend it to someone who likes aerobatics.
Heres the maiden: [media]http://www.youtube.com/watch?v=e7xL6HNqeik[/media]
SEE MORE PICS HERE-JUST SCROLL DOWN, YOU'LL SEE BOTH: http://reddevilsquadronrc.wordpress.com/planes-for-sale/
ID:	105202   Click image for larger version
zdsweet is offline
Sam_K
12-31-2007 06:37 AM
bgfireman
11-17-2007 03:33 AM
pappy60
ParkFlyers
24
11-15-2007 05:06 AM
Huntermd14
04-27-2007 04:24 PM
wichet
3D Flying
04-04-2007 10:51 PM
Quick Reply: For Sale Mini Ultra Stick (Stik)
Page generated in 0.06313 seconds with 16 queries
