What would you like to see built? - Page 4 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-27-2007, 04:41 PM
  #76
Biplane Murphy
2 Wings, Twice The Fun
Biplane Murphy's Avatar
Originally Posted by FlyingMonkey View Post
Careful here... It covers you under specific conditions. If I remember correctly, if you're flying at your house, and put a slow stick through a neighbor's window, you're not covered. I think you have certain locations that they cover you for.
It seems that the insurance is secondary to a homeowners policy or any other insurance you may have
There is debate about where you are covered and not.........One reason i just fly at the club field......Covered there for sure!!!.....
I think I will call AMA and ask.....I have seen this debated many times, so an answer from the "parent club" may be the way to go.....
Biplane Murphy is offline
Old 08-27-2007, 08:45 PM
  #77
xuzme720
c'mere Monkey
xuzme720's Avatar
AMA sanctioned flying fields only...
xuzme720 is offline
Old 08-27-2007, 11:35 PM
  #78
smokejohnson
smokejohnson's Avatar
I think that is watt Murph is talking about. I thought as long as it falls in to the AMA guidelines for watt represents a safe field you are covered.
smokejohnson is offline
Old 08-27-2007, 11:43 PM
  #79
Biplane Murphy
O.K......I CALLED AMA MEMBER SERVICES today.......you/me/we are covered anytime and anywhere!!!!
The one thing that does apply is that the AMA safety code has to be adhered to!!
If you do not follow the code you may be at risk of exempting your coverage......
This is directly from an AMA member services representative....
AMA code:
http://www.modelaircraft.org/PDF-files/105.pdf
Insurance summary:
http://www.modelaircraft.org/PDF-files/500-A.pdf
There are rules involved, but if followed AMA members aree insured in places other than Chartered Flying Clubs.
Fly Safe........especially you "Freddo".
Old 08-28-2007, 01:03 AM
  #80
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Default Hawker Typhoon Updates
Murph thanks for the info on the AMA. Definatley going to join, mau wait to join a club. With my work schedule its hard to have any real spare time.
Back to the Typhoon as I type this message I'm printing out the 24 pages of the first sheet, then once thats done its time to cut and tape the pages together. Going to wait for the wing pages, no since in printing them out and losing them. Once started and going smooth I will start a new thread.
Just to give you guys an idea of the build process check out these builds...P-40 70.5" wingspan
and FFF Corsair.
Heres how I cut my ribs. Take the template and trace it onto some balsa or formica (floor tile) then sand to finish shape and where they match. Then tape them together so don't move. Drill 2 holes roughly where you want your CF rod going, then using a brass tube push it through the foam and sandwhich the foam between the template. Then just use a cheap hotwire from a crafts store to cut them out. I'm going with .5" foam for ribs for strenght and more surface area to glue.
Water Boy is offline
Old 08-28-2007, 01:12 AM
  #81
Biplane Murphy
Hi Harry....if you know an architect or engineer....they uually have plotters that can print things like plans if they are in the right format....
so you decided on the Typhoon.....sweet!!!
cool...good decision to join up....fly as a guest and meet the local pilots etc.....
Old 08-28-2007, 01:16 AM
  #82
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Well I'm kinda in the market for a plotter right now because of the many pages I print. Been searching Ebay and found a couple potentionals, but shipping is way expensive, so local pick up is almost a must. There is a possiblity to by new.. but it needs to be in the price range.
Old 08-28-2007, 02:36 AM
  #83
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
Check this card model I found of the Typhoon. Would be great for a
simple foamie profile. Check out the inscriptions, the one about the fire is hilarious.
Name:	Typhoon colored.jpg
Old 08-28-2007, 03:57 AM
  #84
Biplane Murphy
I tried to read it but when I click on the image and expand the writing looks like Russian....
Old 08-28-2007, 03:58 AM
  #85
smokejohnson
Same here watts it say??
Old 08-28-2007, 03:59 AM
  #86
Water Boy
☺ ↓ My co-pilot ☺
Water Boy's Avatar
When you click on the pic, look in the bottom right corner. Theres a little purple square tingy, click on it to show actual size. I don't want to ruin for everyone else
Old 08-28-2007, 04:04 AM
  #87
Biplane Murphy
HAHAHA..........I think you need to put all that British humour on yours.....Scale plane and all.
I never knew about that purple icon...neat trick!!!
Old 08-28-2007, 04:18 AM
  #88
smokejohnson
Thanks Harry. That is funny, I liked watt was written on the tail also.
Off Topic Chit Chat
20
01-12-2009 08:35 PM
GreenAce92
Special Interest Aircraft
16
11-09-2008 03:05 AM
quailbird
Aerial Photography
05-24-2007 07:43 AM
rocket_jim
Foamies
02-26-2006 03:58 PM
FinnFlyer
Seaplanes E-Powered
02-04-2006 12:46 PM
Quick Reply: What would you like to see built?
Page generated in 0.07621 seconds with 15 queries
