Getting paper off foam board - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 08-27-2007, 05:52 AM
Balsa_Butcher
Default Getting paper off foam board
I gave a sheet of black Elmer's foamboard from Walmart a QUICK shot of STP carb cleaner just to see what would happen. I did not soak the paper only a light spray. I waited 20 seconds and off the paper peeled! Like magic! Be careful around the edges.I stripped 10 sheets in under 30 minutes like this. It works! Spray and then start pulling from a corner to see if it's loose. It's easy.
I didn't damage a single sheet.
Balsa_Butcher is offline
Old 08-27-2007, 06:11 AM
Wow your brave If it works for you, Great, I just sand the paper to get the shine off, and soak the foam board parts, after they are cut out, in the bath tub over night, with a wet towel on top of the pieces, and rub any glue that might be on the foamboard with a wash towel, under water, works great for me, and no harmful chemical fumes, Take care, Chellie
Old 08-27-2007, 06:10 PM
soar-ne
Omaha Ne.
I have heard that too. I think it is mostly alcahol and have heard of people spraying it with windex with rubbing alcy added. Also windsheild washer fluid is said to work with more alchy added. Like Chellie I just use good old water for a while after I cut out the parts......
Good Hint though
Bob
soar-ne is offline
Jody
Foamies
21
02-06-2010 06:05 PM
Epowerreg
05-08-2008 01:15 AM
pcs2007
ParkFlyers
21
03-16-2008 07:52 PM
Water Boy
Foamies
09-08-2007 05:05 PM
Saucerguy2
Foamies
19
07-27-2007 01:10 AM
Quick Reply: Getting paper off foam board
Page generated in 0.05099 seconds with 13 queries
