What's the correct motor pitch when mounting to a firewall? - Page 2 - WattFlyer RC Electric Flight Forums - Discuss radio control eflight
Old 09-01-2007, 07:08 AM
smokejohnson
smokejohnson's Avatar
Originally Posted by phupper View Post
So the answer is, to move the CG back, add weight to the tail?
Or take weight off the nose for the same effect.
smokejohnson is offline
Old 09-01-2007, 07:10 AM
xuzme720
c'mere Monkey
xuzme720's Avatar
Originally Posted by smokejohnson View Post
Correct. But don't add weight, take it off so it will fly better .
sorry! your right, for some reason I was thinking the other way...guess my pain meds are better than I thought!
xuzme720 is offline
Old 09-01-2007, 07:58 AM
phupper
Flyin' Phup
phupper's Avatar
No prob! I've done that, glad we're all on the same page.
Ok I extended the landing gear forward so the nose won't dip on takeoff. Yeah I know it's ugly, but it's just for testing. I also changed to a smaller lipo. The CG is now at 2".
I have a good feeling about the next test flight. But who knows, that could be the nylon-reinforced-packing-tape talking. I'll post results.
phupper is offline
Old 09-01-2007, 02:03 PM
pd1
Still Learning
pd1's Avatar
phupper, Yes, remove weight from the nose or add weight to the tail.
Also this brings up a new question.
If the plane was nose heavy, why did it climb a lot on you?
Check the incidence of the horizontal tail.
Make sure the stabilizer is parallel to the wing.
It was late last night I think we all were missing things.
Paul
pd1 is offline
Old 09-01-2007, 06:44 PM
xuzme720
c'mere Monkey
xuzme720's Avatar
Paul
lol, that is being generous, Paul! but I think that is the main reason I was trying to go in the other direction, the climbing had me thinking it was tail heavy...
xuzme720 is offline
Old 09-01-2007, 09:02 PM
phupper
Flyin' Phup
phupper's Avatar
"If the plane was nose heavy, why did it climb a lot on you?"
I think because the prop was too large. I had to take off with a lot of up-elevator to keep the prop from hitting the ground as the tail lifted. Moving the wheels forward as I did, should make the tail stay down during takeoff. I should be able to take off with little up-elevator now, and climb more slowly.
phupper is offline
Old 09-01-2007, 10:00 PM
pd1
Still Learning
pd1's Avatar
phupper, Don't forget to let us know how it flies this time.
Paul
pd1 is offline
Old 09-04-2007, 05:06 AM
phupper
Flyin' Phup
phupper's Avatar
It flies! I ended up taking the advice and cut off some of the nose, then moved everything back a few inches. The CG is now at about 1.75" back. Along with moving the wheels forward, takeoff was nice and smooth.
My first actual RC plane flight, I was surprized that it flew exactly like the simulator. I did 2 laps around the field like a pro. Then on a downwind leg, my prop-saver screws losened. When I lost power I was heading for trees. With no time to land, I had to let it glide over the trees toward an adjacent field, and out of sight. Funny, I think I was still trying to fly it in for a landing, even though I couldn't see it. The only part that broke was the tail, coincidently this was the only place I didn't cover with nylon packing tape (that stuff is amazing).
I thank you guys for all your help. I learned a lot of fundimentals of plane design. A few minor mods on this trainer, and some practice, and I'll be confident enough to try flying a nicer plane (like the Simple Corsair I built). I love my new hobby!:p
phupper is offline
Old 09-04-2007, 05:12 AM
smokejohnson
Congratulations phupper, I'm glad to hear it went well for ya. I like to use Blue Loctite on my screws on the motor mounts and prop savers.
Old 09-04-2007, 08:42 AM
Thats great Glad your getting the hang of it I agree with Johnson, use some blue lock tight on the prop saver, Also, where the prop saver screws meet the motor shaft, grind a flat spot on the shaft, that will keep the prop saver from wanting to spin on the shaft, just a little some thing that I learned on Wattflyers Take care & have fun, Chellie
Old 09-04-2007, 12:50 PM
pd1
Still Learning
pd1's Avatar
phupper, Great news.
Paul
pd1 is offline
grant_gibson45
10-08-2008 10:01 PM
Angler-Hi
03-31-2008 06:54 PM
Jake T.
02-25-2008 01:53 AM
diablo
Brushless Motor Construction
04-17-2007 07:33 AM
stefanv
12-18-2006 08:02 PM
Quick Reply: What's the correct motor pitch when mounting to a firewall?
Page generated in 0.10365 seconds with 13 queries
