Honeybee King II with DX6i setup
Old 05-24-2008, 03:24 PM
quickshift
Default Honeybee King II with DX6i setup
Hi, I'm new to heli. Own a Honeybee King 2 w/ 3100kv brushless motor, 25A ESC, Telebee GR302 w/ ATV gyro and a Spektrum DX6i w/ AR6200 receiver bundled. I'm having difficulties setting up my DX6i with my HBK2. Anybody can help? Thanks.
quickshift is offline
Old 05-25-2008, 03:33 AM
captksmh
give specific problems and we can most likely help
captksmh is offline
Old 05-26-2008, 11:37 PM
quickshift
Do I have to bind after each modification on the TX? What is stunt mode in the DX6i?
Old 05-26-2008, 11:44 PM
Balil
foam murderer :D
Balil's Avatar
no you do not have to rebind after each setup modification, the reciever and tx both remember the setup. and your idle up switch is on the left side of the tx, you can setup your idle up settings under throttle curve and the pitch curve menus, any other questions you have just shoot. i'll break out my dx6i and figure out any setup problems you have
Balil is offline
Old 05-27-2008, 06:16 AM
quickshift
what is the best setting for idle up mode?
Old 05-27-2008, 06:41 AM
Balil
foam murderer :D
Balil's Avatar
look in your owner's manual for the hbk2 and see what it says your pitch settings should be. on the b-400 i have i was +12/-12 on idle up with a throttle curve of -100% -50 0 +50 +100, usually the manual will tell you what the recommended the pitch and throttle curves for that paticular heli.
Balil is offline
Old 05-27-2008, 07:51 AM
quickshift
the manual said normal pitch is lowest stick -2, middle stick 0, highest stick +7. Idle is lowest stick -7, middle stick 0, highest stick +7. didn't say about the throttle curve...
Old 09-30-2008, 02:22 AM
slotdr
Default Dx6i setup with HBK2
hello all
I have tried so many settings and my HBK2 felt better with the stock TX & RX. I would like the settings like the stock TX, I can't find a listing for the stock settings so that I can input into the dx6i. can someone with a HBK2 and dx6i send me there settings, I just hover and fly around no tricks
slotdr is offline
BGBEST
Beginners - Helis
17
12-08-2007 06:07 AM
bobbyjy
Beginners - Helis
12-02-2007 08:36 PM
Djob
Beginners - Helis
11-02-2007 05:04 AM
Frodo
General RC E-Heli Talk
04-15-2007 04:47 AM
Turbojoe
15
09-03-2006 04:15 PM
Quick Reply: Honeybee King II with DX6i setup
Page generated in 0.11187 seconds with 13 queries
