Advise on power set-up
Old 08-25-2008, 11:45 PM
htomnlinda
htomnlinda's Avatar
Default Advise on power set-up
I'm building a Clancy Lazy Bee 60". Its going to have two servos for rudder and elevator.
The power for this bird will a 4248-07 out runner motor producing 91 oz thrust. APC 13X6.5 prop, and a pair of 2100 mah 11.1 volt lipo's.
I'm planning on joining this up with a 70 A ESC.
Question should I also install a 3Amp UBEC
Thanks All
htomnlinda is offline
Old 08-25-2008, 11:46 PM
Figure.N9ne
Figure.N9ne's Avatar
Thanks All
on 3s lipo and with only 2 servo's you'll be fine without an external bec, assuming your esc has a bec already. if the lipo's are in series then i'd go with the external bec.
Figure.N9ne is offline
Old 08-26-2008, 10:38 PM
htomnlinda
htomnlinda's Avatar
Thanks for your imput, I'll do just that !
Dorsal
09-30-2007 01:57 AM
Tinman
06-27-2007 09:39 PM
Blue Max
02-25-2007 07:31 AM
RickAvery
10-03-2006 03:51 PM
Quick Reply: Advise on power set-up
Page generated in 0.06653 seconds with 13 queries
