Is this a good choice switch for my setup?
Old 09-12-2008, 02:48 AM
747's Avatar
Default Is this a good choice switch for my setup?
For my sig rascal 40 EP conversion having a 5sa123 pack, no bec , 70 A esc , Brushless Outrunner OK-C4250 (3520) KV 600, 4 servos ,Futaba 6exa radio system .
I have a nicd 4.8v 1000mah battery for its Receiver. There is a switch with 3 leads: The battery , The Rx, Then the charge lead. I want to replace that switch with a type that has the charge pin built in the switch itself , like this Eg:
http://www3.towerhobbies.com/cgi-bin...&I=LXPNU2&P=ML
So I bought it ! Just tell me is this too heavy duty for this setup.
Is this a good choice? Just wanna confirm since the switch didnt come with Amp ratings or any power/Volts info and don't wanna create undo drop in "V" if it is ONLY for big Rx batteries!
747 is offline
Old 09-17-2008, 07:50 PM
Matt Kirsch
Matt Kirsch's Avatar
Actually, the heavier-duty the switch, the LESS drop in "V."
If you've got the space and can take the weight, that is an excellent switch. I like them because you can cut one larger hole instead of one small hole, two smaller holes, a second small hole, and two more small holes to mount a conventional switch and an Ernst charge jack.
Matt Kirsch is offline
mizzouHHR
08-09-2008 07:34 PM
Mac1z
30
07-30-2008 03:46 AM
VCtony
Aerial Photography
07-07-2008 07:19 AM
SkunkyMagoo
04-15-2008 04:35 PM
ruapilot2
Delta & Flying Wings
01-13-2007 05:16 AM
Quick Reply: Is this a good choice switch for my setup?
Page generated in 0.09741 seconds with 13 queries
