Caps 580 / 30 Lb Motor Set-up
Old 10-02-2008, 08:06 PM
Fly Robert
Default Caps 580 / 30 Lb Motor Set-up
My question is would the motor below power this 28LB plane Caps 580 with a 14S set-up
according to the math it would be around 5700 watts / 190 watts/Lb
do you think is worthy motor ? it's only $150.00
Model: HXT80-100-B
Wire Turns: 8
Resistance: 32ohm
Idle Current: 2A
ESC Required: 130A
Input Voltage : max. 48V
Kv : 130 rpm/V
Weight: 1570g
Shaft: 12mm
Voltage Range: 20-48v
Non Load Current: 2.0A
Maximum Power: 6500W
Equivalent: 60-80cc Gas Engine
Fly Robert is offline
Old 10-03-2008, 06:08 AM
Larry3215
Look out for that tree!!!
Larry3215's Avatar
You could 3D the plane with 190 watts/pound. Thats more than enough power.
As to whether or not the motor would actually survive at its rated power - I doubt it.
The specs on the Hobby City stuff are usually wishful thinking at best and outright inventions at worst.
I have yet to see any of those motors made with metal parts that could survive at anywhere close to those power levels. The last one I tested was rated to 2000 watts and began to fail before I reached 1000 watts and was grossly unsafe. The aluminum parts were not tempered at all. No way the motor and especially the prop adaptor could handle the stresses.
Be careful and good luck!
Larry3215 is offline
Old 10-03-2008, 02:20 PM
Fly Robert
Thanks,
you know I was thinking the same thing on a motor with that much power,
I may have to look at another motor may the Hacker A-100 0r A-150 didn't want to shell out almost $1,000.00
Old 10-03-2008, 05:31 PM
Larry3215
Larry3215's Avatar
The big Hackers are actually a pretty good deal as far as watts/$$ go and they will actually do the dance without killing you or an inocent bystander by shedding a 24" prop at hi power levels.
Unfortunately, you are also going to have to shell out for a name brand controller if you want to play in that power range.
The Hobby City hi voltage controllers are even worse than their normal stuff. Their HV controllers cannot even come close to performing at thier full rated values.
If the controller says it can do 12S at 100 amps you'll be very lucky if it survives on 10S at 75 amps in short bursts - less than 1/2 the power you want.
Your going to have to get a Kontronic Power Jazz 63 controller or special order one of the new Castle SHV controllers - if they are making them yet.
Jetti is suposed to have a new 14S or 15S controller out as well but I dont know anything about it or if you can even get one yet.
ed3
10-09-2008 04:25 PM
Gryphon
05-24-2008 05:33 AM
Twmaster
Support & Suggestions
01-23-2008 01:12 PM
UncleBob
16
09-25-2007 09:52 PM
y1gkg
01-02-2007 06:32 PM
Quick Reply: Caps 580 / 30 Lb Motor Set-up
Page generated in 0.09812 seconds with 13 queries
