IMAX B6 charger set-up question
Old 08-22-2008, 06:03 PM
skylane42
Default IMAX B6 charger set-up question
I have a question on the IMAX 6B. I am charging my Rx nicad pack and the charger will only show MAN .. how do I switch it to AUTO? In the instruction book it talks about AUTO and shows Auto in the illustrations.
skylane42 is offline
Old 08-22-2008, 06:22 PM
ministeve2003
Class Clown
ministeve2003's Avatar
I never could figure that out myself... I just use man... it works without a hitch... I'm not really sure what Auto would do anyways...
SK
ministeve2003 is offline
Old 08-22-2008, 06:29 PM
SkunkyMagoo
Newborn Rotorhead
SkunkyMagoo's Avatar
I just figured it was engrish and man = mah! Works for me I charge my 1500mah nimh at 0.3a
SkunkyMagoo is offline
Old 08-22-2008, 06:42 PM
ministeve2003
Class Clown
wow, that slow..lol I usually charge at 1c for all my nimh packs.... but maybe I should make it a little easyier on them...
SK
Old 08-22-2008, 06:58 PM
skylane42
I would normally just charge at a lower amp.. but the problem is that the charger will charge the 4.8v pack to 7 volts.. I don`t like that. I then discharged to 5 volts.
Old 08-22-2008, 07:04 PM
SkunkyMagoo
Newborn Rotorhead
That is fine and normal. My 9.6 gets charged to over 12.
Old 08-22-2008, 07:11 PM
ministeve2003
Class Clown
yes, my 9.6 ends up 12 also...
immediately it drops to about 10.5 and then within a minute or two...drops to maybe 9.9 or so under load that way...
SK
Old 08-25-2008, 06:14 AM
Sir Raleigh
If you guys are still interested, to switch back and forth between MAN and AUTO press both the INC and DEC buttons at the same time.
Sir Raleigh is offline
Old 08-25-2008, 06:38 AM
ministeve2003
Class Clown
So what does auto do?
SK
Old 08-25-2008, 04:42 PM
Sir Raleigh
To be honest I have no idea...
I leave mine in AUTO and set it to 1C of the NiMH pack I'm going to charge and it charges it at 1C.
I've not even tried the manual mode.
cbatters
08-02-2008 11:27 PM
Larry G
22
06-10-2008 09:42 PM
vonveska
03-07-2008 11:28 AM
daniirwan
11
02-25-2008 10:04 PM
kalel
12-20-2007 08:26 AM
Quick Reply: IMAX B6 charger set-up question
Page generated in 0.07518 seconds with 13 queries
