***What is a good first personal radio***
Old 09-04-2009, 12:55 PM
superd333
Back From a 0.5 year ban!
superd333's Avatar
Exclamation ***What is a good first personal radio***
Hey guys,
I'm investing in my first "Personal" radio.
what is a good 2.4ghz, 4ch radio?
Also i would like to have a receiver or two that work with it.
willing to spend a few hundred, but no more.
thanks
superd333 is offline
Old 09-04-2009, 01:31 PM
Lieutenant Loughead
UNCLUB OWNER
Lieutenant Loughead's Avatar
Hmmm -- Your $200 spending limit is going to be a serious limiting factor. Let me ask you a question -- do you think you're going to spend MONTHS, or YEARS in this hobby?
If the answer is MONTHS, then I'd suggest a used 72MHz radio on eBay -- something like a Hitec Optic 6.
If the answer is YEARS, then I'd suggest a new Spektrum DX6i (or even a DX7, if you can afford it).
In either case, a good quality receiver is going to cost you about $50 each -- so it's going to be difficult to find a radio and two receivers for $200. :o
If you're looking for something to just try out, send me a PM. I may have a couple of options for you.
Best of luck!
Old 09-06-2009, 02:27 PM
superd333
superd333's Avatar
Im so sorry i wasn't able to respond earlier, i had some problems with my account.
I will be in the hobby for years if not decades hopefully.
So i want to get a 2.4ghz.
i will be first flying 4ch, but can see in the future moving into some 6ch planes.
if i buy a 6ch radio, will i be able to use it in a 4ch plane, with the 6ch receiver?
thanks
Old 09-06-2009, 03:56 PM
jkaven
jkaven's Avatar
thanks
Yes
Get a DX7. You'll get a 20 model memory compared to the 10 on the DX6i. 20 models may seem like a lot but if you really enjoy the hobby you'll hit 10 pretty quickly. Plus you might want to use two memory slots for setting up a plane and helicopter on a sim. I almost bought the DX6i but I'm glad I got the DX7 because after a year I'm over 10 models.
jkaven is offline
Old 09-06-2009, 04:02 PM
Bite the bullet, DX7. Then pick up some ar6000 rx for cheap (ish) for pakflyers and get ar6200 or ar7000's for when you get into the bigger planes.
To answer your other question, you can use a 6 channel RX on a one, two, three channel etc. set-up.
Old 09-06-2009, 04:10 PM
superd333
superd333's Avatar
is this a good radio? http://www.rcplanet.com/Futaba_6EX_6...p/futk6900.htm
also, say i get an ARF plane, will all radios and recievers work with the servos in the ARF (almost ready to fly)?
thanks
Old 09-06-2009, 05:05 PM
idealhobbies
idealhobbies's Avatar
Yes, the radios and rx's will work with ARF's. For a radio, keep your eye out for a used Spektrum DX7. It's an outstanding radio, you don't need an engineering degree to program it, and the menues are clear and relatively easy to understand. Buy it used and save a few dollars. If you have concerns with it, you can send to to Horizon Hobby and have a tech go over it...often for free...
idealhobbies is offline
Old 09-06-2009, 05:06 PM
Lieutenant Loughead
UNCLUB OWNER
Futaba is a good brand name, but I'm sorry to say I know nothing about that radio. The advice you have been offered above is best -- get a Spektrum DX6i, or DX7 if you can afford it. Click on the links to learn more about those systems. You can find some good deals on eBay, if you search for them.
Yes, all radios and receivers will work with the servos in the ARF airplane. However, if you buy a "Bind and Fly" airplane, it will only work with a Spektrum system.
slipstick
Yes that's good radio but many of us prefer Spektrum. If you can't afford a DX7 the DX6i is roughly equivalent to the Futaba 6EX and Spektrum make a greater range of receivers, some of which are a lot cheaper than Futaba receivers.
BTW most ARFs don't come with servos. You have to buy your own. Perhaps you're thinking of PnP models like some of the Parkzone ones. Anyway almost all servos are compatible with almost all receivers. There are only a few exceptions, mainly in some very small models which use non-standard connectors.
slipstick is offline
Old 09-06-2009, 05:44 PM
TDisaster
TDisaster's Avatar
Or you could get away from the main stream and go Airtronics.
I have not had one issue with Airtronics 2.4, ever. I've had brown outs on Spektrum (my fault), but I don't have to worry about that with Airtronics.
http://www.hobbypeople.net/gallery/751700.asp
I have both of their 2.4 air radios (the RDS8000 and SD-10G) and absolutely love them. I'm also using their MX-3FHSS 2.4 car radio. They just stopped the RDS8000 for 220$ with two receiver deal, but they have the RDS with 1 receiver for 140$ right now, which no one comes near in the price range. Airtronics receivers are also on the cheaper side. Their 8ch is cheaper then Spektrum's 7ch. Airtronics 7ch is about the same as the full range 6ch Spektrum receiver. And their "parkflyer" receivers are the same price as Spektrum's.
Just makin' sure you know Spektrum isn't the only one out there.
TDisaster is offline
Old 09-06-2009, 08:28 PM
superd333
superd333's Avatar
thank you to all.
I guess the spectrum seems to be the most popular brand.
i am going with the DX6i, i wont be above 10 planes for a while.
Where can i get this radio, where it comes with a receiver or two?
linky lniky. please
thanks
Superd333
Old 09-06-2009, 09:01 PM
Lieutenant Loughead
UNCLUB OWNER
http://www.hobby-lobby.com/dx6i_full...QueryId=178893
http://spektrumrc.com/Products/Defau...ProdID=SPM6620
http://spektrumrc.com/Products/Defau...ProdID=SPM6600
The last two links are to the Spektrum web site. On the right side, you can enter your zip code, and find local hobby shops which carry the DX6i. That way, you can look at it before you buy it.
Best of luck -- let us know how it turns out!
Old 09-06-2009, 09:05 PM
superd333
superd333's Avatar
thanks, Will do!
Old 09-06-2009, 10:26 PM
Cool! For a "few" hundred, you should be ables to get a few receivers also!
Old 09-06-2009, 10:32 PM
aramid
aramid's Avatar
I'm a big fan of the Spektrum radios, mostly because the receivers are so cheap compared to everyone else's 2.4 equipment. I actually prefer the DX6i over the admittedly more capable DX7, just because I think the menu system on the 6i is nicer. Really, for anyone who doesn't spend a lot of time playing with mixes and doesn't plan to fly complex helicopters, I think the only benefit the 7 has over the 6i is twice the model memory.
Remember, if you're using Spektrum radio equipment, you need a strong power source for the radio and servos. Typically this means using a switchmode BEC if you're running on 3s or higher LiPo, or using a separate receiver pack. The normal linear BEC built into most speed controllers is only acceptable on 2s LiPo, where it'll stay much cooler and provide more power.
aramid is offline
Old 09-08-2009, 03:39 PM
superd333
superd333's Avatar
how do you do elivon mixing with the DX6i?
thanks
Old 09-08-2009, 04:00 PM
aramid
aramid's Avatar
Elevon mixing is just another option in the menu, as I recall, but I've heard that it doesn't work quite the way people expect it to. I've also found, but not tried, this approach.
aramid is offline
Old 09-08-2009, 07:28 PM
Lieutenant Loughead
UNCLUB OWNER
How could elevon mixing not work the way people expect it to? It's a pretty simple function! :o
Old 09-08-2009, 08:58 PM
Nitro Blast
Nitro Blast's Avatar
Elevon mixing, without using the Elevon setting, allows for 'coupled' elevons...
[media]http://vimeo.com/5578144[/media]
Nitro Blast is offline
Old 09-08-2009, 10:22 PM
superd333
superd333's Avatar
Old 09-08-2009, 10:52 PM
superd333
superd333's Avatar
i think what he means is that there isn't enough throw.
you have to do a few steps to increase the throw. i read about this.
thanks
Old 09-09-2009, 01:19 AM
Lieutenant Loughead
UNCLUB OWNER
How strange. I've ordered DX6i's for customers, but never set up elevons for them. However, I've got elevons set up on my DX7 for my Stryker, and it's just fine...
Old 09-09-2009, 03:40 AM
MustangMan
MustangMan's Avatar
It is pretty simple, but it appears that the firmware author for the DX6i got it wrong.
According to the tests done by the author of the linked thread there are problems with asymmetric throws, limited travel, and complications with trim. His work is reasonably meticulous and he says Spektrum/Horizon has acknowledged all the problem and stated that they will not be fixing them.
With my DX6i I noticed the problem with asymmetric throws giving spiral loops. I crudely attempted to correct it by adjusting endpoints but CRUDELY is the significant word there. It has never flown right. I've also struggled with the reduced throws compared the behavior of other radios. Just about an hour ago I reprogrammed using the suggested mixing method as an alternative to the build-in elevon mix. I'll hopefully be able to test it out tomorrow.
MustangMan is offline
Old 09-09-2009, 04:00 AM
ministeve2003
Class Clown
ministeve2003's Avatar
wow, another problem with the dx6i...?
Buy yourself a used dx7 and forget the 6i and it's faulty scroll wheel that tends to break...
SK
ministeve2003 is offline
Old 09-09-2009, 04:07 AM
SK
or a X9303!
Quick Reply: ***What is a good first personal radio***
Page generated in 0.18204 seconds with 12 queries
