nitromodels f16 pusher?
Old 05-13-2009, 10:21 PM
XWind
Default nitromodels f16 pusher?
Im thinking of buying this plane and coverting it to EDF. Has anyone had any luck and what was the setup? motor/esc/battery..etc. Any help would be great.
XWind is offline
Old 05-13-2009, 11:47 PM
Moxus
Gremlin
got any link to the model?
http://www.nitroplanes.com/ffifaarfbrel.html
is it this one?
Moxus is offline
Old 05-14-2009, 01:14 AM
XWind
Yes, that is the one. Thanks for the reply. Any comments on that one? I heard some complaints about the wing area not to scale but thats ok with me. Im sure it will fly just fine with the right EDF gear put in it.
XWind is offline
Old 05-14-2009, 03:18 AM
Alpea42
Parkjets Rule 3D Rocks
Alpea42's Avatar
The fuse is fiberglass with a lotta ply bulkeads. It's heavy so wing loading is high , and C G is very critical. I saw one guy try 3 times to fly it.It wasn't balanced well and throws were not set up right. I heard his last attemp was with a Turnigy S K out runner equal to a .40. The ground killed it on that 4th attemp. Minni Steve has another one and he's gonna put it together as a pusher and try his luck with it. One problem with a pusher is by the time you get a large enough motor the prop hits when you try to rotate on take off. Ask Steve at Renegades about it. At this thread http://www.wattflyer.com/forums/show...35751&page=224 It sure is a good looking plane
Alpea42 is offline
Old 05-14-2009, 03:58 AM
Moxus
Gremlin
it is about the same dimensions as my het rc f-20 tigershark.
i run it with a hacker b40 8l on a 6cell a123 battery pack, and turnigy 100 amp esc.
this is a bit hard on the wemotec mf 480 that i use, and it does rub a bit against the housing, but it works. the rubbing does eventually stop as the blade tips gets worn down :P i know it sounds a bit "agricultural", but it does really work well. the alternative is to get carbon impeller or something like that, wich costs about the same as a real turbine engine.
anyway, if you go for the minifan 480 setup, check the diameter of your duct/engine bay. if it does fit, i recommend it. becuase its pretty good on performance, and very "all round" (as far as allround goes for edf anyway).
i get over 1 kilo on thrust on my setup, and as mentioned in previous post, you need a powerful motor for this plane. its a bit on the heavy side.
the hacker b40 performs WAY in excess of what its rated for, and i guess the same applies for any hacker motor, or other quality brands (for example, mega or lehner, wich also is popular in the power-edf setups).
Moxus is offline
Old 05-14-2009, 04:30 AM
XWind
hey, thanks for all the comments. I will have to think more about it. The plane really does look sharp and a great bargain.
XWind is offline
Old 05-14-2009, 05:09 AM
Papa Jeff
Default Nitro F-16 Pusher to EDF conversion
I have been working on this for a while now and I think that I finally
have a handle on it. I'll post some photos and a few concepts in the
next few days.
Papa Jeff is offline
Old 05-14-2009, 05:57 PM
XWind
Thanks Jeff. Here is what I think I will need for the setup. Anyone please correct me if I am wrong.
Flight weight- 3.5lbs
Motor- 90mm 700w (72A) EDF Unit, Brushless
ESC- Brushless (72A+)
Battery- 11.1V 3300mah Lipo.
However, according to my calcs the flight time is very very short.
3.3/72Ax60=2.75 minutes(approx). Even if I go with a high mah, flight time is still short.
Any feedback would be appreciated.
XWind is offline
Old 05-14-2009, 06:30 PM
Alpea42
Alpea42's Avatar
My personal opinion is IT'S TOO HEAVY to make a good EDF project. A 3 cell battery will be a weak power sorce. But if Jeff knows what he's up against I'll reserve those opinions and eat those words if he can make it fly. If it interrests anybody the Nitro Planes photo is a photo shop rendition of the plane against the sky. They couldn't even get an in flight picture
Alpea42 is offline
Old 05-14-2009, 06:59 PM
Papa Jeff
Yes, it may be a little heavy, but hopefully with a 90mm EDF Midi fan,
using an Ammo 36 1800kv motor with a Castle HV80 ESC and CCBEC
plus a 4S or 5S 4000-5000mAh pack.......it should fly just fine. Of
course......we shall see! I do agree with Alpea that a 3S pack is not
the best option for this conversion project. Here are a few photos.
Name:	Copy of IMG_3195.JPG
ID:	100939   Click image for larger version
Name:	Copy of IMG_3194.JPG
ID:	100940   Click image for larger version
ID:	100941   Click image for larger version
ID:	100942   Click image for larger version
Old 05-14-2009, 07:03 PM
XWind
Yeah, you are probably right Alpea. Seems like this might be more of a turbine job and thats way too much money for me.
XWind is offline
Old 05-14-2009, 07:07 PM
XWind
Way to go Jeff, it looks sharp, almost there. I hope you post your Maiden flight. Hey, just looking at the specs of your motor, it migh very well work. I calculate at 6min flight time with a 5000mah.
XWind is offline
Old 05-14-2009, 08:21 PM
Moxus
Gremlin
its not too heavy for edf, it just demands power.
my f-20 is slightly over 1 kilo, and its powered by a 78mm fan. a 90mm will with no problem give 1.6 kiloes of thrust, and there you go, vertical performance. 1:1 power to weight ratio.
all the weight means is that you need speed. but isnt speed all what jets is supposed to be anyway?
thats just my opinion, anyway. i rather have a powerful edf with high wing loading, than a depron sheet, cut like the silhouette of a jet fighter, but flies like a leaf in the autumn wind.
the f-20 flies great, and it has even shorter stubbier wings than this f-16. all you need is speed. and a strong buddy to be your catapult, unless you actually got a catapult.
these models are surprisingly kind on landing too, with no nasty tendencies even with high nose on landings. just let them have their speed. dont take the speed down. thats bad.
Moxus is offline
Old 05-14-2009, 09:18 PM
Alpea42
Alpea42's Avatar
Yeah that really looks nice Jeff. The speed thing is the right thing. But a sagging battery or too high of AOA or any number of other goofs and even Capt. Scully couldn't glide it in to the Hudson River. It should be fine tho with all that thrust.
Alpea42 is offline
Old 05-19-2009, 10:12 PM
Papa Jeff
Default More photos
I did a few more mods and I just ordered some saddle packs. I'm
going for two 3S 5000's on each side of the EDF and I hope that
the battery weight over the CG will do the trick better than forward
under the cockpit. We shall see!
Removing formers & tray.
ID:	101382   Click image for larger version
ID:	101383   Click image for larger version
Old 05-19-2009, 10:20 PM
Papa Jeff
96mm MPI EDF unit was a perfect fit.
ID:	101385   Click image for larger version
ID:	101387   Click image for larger version
ID:	101388   Click image for larger version
Old 05-19-2009, 10:29 PM
Papa Jeff
I did take the time to make the wings removable as the full length of the
wing tube went through the fuselage just where the EDF unit had to go.
ID:	101397   Click image for larger version
ID:	101398   Click image for larger version
ID:	101399   Click image for larger version
Old 05-19-2009, 10:39 PM
Papa Jeff
I did make some changes to the hardware that came with
the Nitro F-16 and basically it just made me feel a bit more
secure.
ID:	101401   Click image for larger version
ID:	101402   Click image for larger version
ID:	101403   Click image for larger version
ID:	101404   Click image for larger version
Old 05-19-2009, 11:38 PM
XWind
Very Cool, getting closer!
XWind is offline
Old 05-20-2009, 12:13 AM
Moxus
Gremlin
looks nice so far keep us updated, this is interesting
Moxus is offline
Old 05-20-2009, 10:03 AM
Alpea42
Alpea42's Avatar
Nice modifications Jeff. 2 5000ma 3s batteries huh? Looks like you'll be over 5 lbs. flying weight.
Alpea42 is offline
Old 05-26-2009, 05:17 PM
Alpea42
Alpea42's Avatar
So Jeff got a flight report yet? I'm beggining to think you're very busy , or it was an over weight disaster that wouldn't lift off a cliff.
Alpea42 is offline
Old 05-26-2009, 06:34 PM
Moxus
Gremlin
there is no such thing as overweight, just underpowered =)
when you think you got enough power, then twice the amount you got is about nice.
Moxus is offline
Old 05-26-2009, 07:44 PM
Alpea42
Alpea42's Avatar
O k then, hey Jeff did you have enough power???
Alpea42 is offline
Old 05-26-2009, 08:16 PM
Papa Jeff
Default F-16 EDF
Alpea,
Well, you are kinda right, as i did get somewhat distracted with another
project that had to get done first. This weekend we maidened the Fly
Fly F-86 and it was most successful. The flying weight was 5.85 lbs. of
which 1.5 lbs. was the two 3S / 4050mAh / 30C Enerland packs. And,
there was no issue with power as 3/4 throttle produced an estimated
90-100 MPH. So, now I am confident that the F-16 will not be lacking
in power either as it should come in at about 4.5 lbs flying weight. Here
are a few photos. Now, back to the F-16.
Name:	Copy of IMG_1386.JPG
ID:	101971   Click image for larger version
Name:	Copy of IMG_0800.JPG
ID:	101972   Click image for larger version
Name:	Copy of IMG_0853.JPG
Quick Reply: nitromodels f16 pusher?
Page generated in 0.12560 seconds with 38 queries
