DX6i won't work
Old 03-17-2012, 05:52 AM
TylerJCooper
TylerJCooper's Avatar
Default DX6i won't work
Today I turned on my DX6i and it will only beep and blink a couple times a second.
******F.MODE******
******T.HOLD******
Any thoughts?
Tyler
TylerJCooper is offline
Old 03-17-2012, 07:09 AM
******F.MODE******
******T.HOLD******
Any thoughts?
Tyler
I'm assuming you've checked the transmitter battery with a separate digital multimeter?
Ref http://www.wattflyer.com/forums/showthread.php?t=52821
Old 03-17-2012, 08:28 AM
Past President of PSSF
I think that means throttle hold. Check your throttle hold switch, if it is in the wrong position, the radio won't turn on.
It would be in a heli mode, when this happens.
Wildflyer is offline
Old 03-17-2012, 09:43 AM
Yep. The throttle hold thing got me, too.
Old 03-17-2012, 02:34 PM
Heli Jim
Grandpa, Golfer, Pilot
Heli Jim's Avatar
yup you need to turn off the throttle hold and the flight mode needs
to be in normal position when you power on the transmitter
Heli Jim is offline
Old 03-17-2012, 03:59 PM
TylerJCooper
Thank you!!!! You were all correct. I flipped the throttle switch and it beeped and blinked in F.MODE. I turned that switch and we are back up and running. I recently moved up from a MSR to a SR and was doing some work with it last night. I was not aware that those settings would withhold me from turning on the remote.
THANKS!!!
Hose Man
08-29-2011 07:35 PM
Swanj
08-26-2011 06:19 PM
morengin
03-06-2011 01:39 AM
NJSwede
01-02-2011 12:22 PM
Quick Reply: DX6i won't work
Page generated in 0.08844 seconds with 13 queries
