Tower vs. Horizon 3.7v battery connection colors
Old 08-15-2019, 01:05 AM
Griff Murphey
Default Tower vs. Horizon 3.7v battery connection colors
I have an old beat up rattletrap Horizon micro Stearman. The battery connector is behaving like the plug is no good. I have a couple of plugs I can pull off off of old wrecked Tower Micros. Problem is the Horizon wires are black and white and the old Tower leads are red and blue. How would I connect a tower plug to a Horizon brick?
Griff Murphey is offline
Old 08-15-2019, 03:31 PM
ron_van_sommeren
homo ludens modelisticus
ron_van_sommeren's Avatar
black = blue = minus
white = red = plus
But why not remove wires completely, or buy new plugs?
Connector tests, plus pictures
translate...www.elektromodellflug.de/hochstrom-st.-bu..html
Older version of that page, contains some other connectors
translate...www.elektromodellflug.de/oldpage/hochstromst/hochstromstecker.htm
Excellent site, do have a look at the controller, motor, charger, power supply, battery etc. tests.
DIY connector soldering jig
wattflyer.com/forums/showthread.php?t=79119
Connector 'saudering' videos
www.innov8tivedesigns.com→ resources → video classroom → soldering videos
Vriendelijke groeten Ron
ron_van_sommeren is offline
Old 08-15-2019, 04:36 PM
Griff Murphey
Steve R Horizon called me at 7pm CDT as they were closing up and said he was not sure but would get out a meter and figure it out. Then 5 minutes after 7 he called back at told me the same thing you just said: blue to black and red to white.
The intermittent Electrical connection when the battery was bring installed pretty well convinced me that itís just the plug to the 3.7v battery.,. I think splicing the wires, which I have done before on high time models (257 flights on this one) is a simple effective option vice trying to do a major rewire?!? Which is likely beyond my simple level. Iíll let you know if it restores my old bird as soon as I get it done.
And... big thanks!
Old 08-16-2019, 12:27 AM
Griff Murphey
Default Success!!!
Easy fix. Staggered the solder joints and covered with heat shrink tubing!
11-14-2021 06:11 PM
11-02-2021 02:03 PM
05-28-2020 10:50 PM
23
07-08-2011 03:40 AM
Murocflyer
03-06-2011 10:48 PM
Quick Reply: Tower vs. Horizon 3.7v battery connection colors
Page generated in 0.08796 seconds with 11 queries
