Sliding canopy
I'm making a model of the 1/8th scale Spitfire MkVb as used in the far east etc ..with the brown camoflage job.....
I would like some help with an idea. I want to have the cockpit area as a route for cooling airflow to escape.....My idea is to make the canopy slide (using a servo) so that I can vary the cooling effect...Winter closed, Summer open...sort of thing..
If anyone has come up with a reliable and successfull way of sliding a canopy back with a servo, (or any other way!) I would really like to hear from you..
Thanks in advance
Ray
Thanks in advance
Ray
Ray,
I saw this done a while back. The builder built balsa rails and a receiver rail on the canopy. He used a pull-push system at first, but found it didn't retract as far as he would like it too. He ended up changing over to a pull pull with pulley's. It was pretty intricate, but doable. I wish I could remember where I saw it, but it has been years ago.
Well, if it is just a seasonal thing, there's no need for a servo to open and close it twice a year.
I would just make some sort of channel system, and frame the bottom of your canopy so that it would slide in the groove.
Ray,
Found this, which is similar, the guy has a sliding door on his DC-3
http://www.rcgroups.com/forums/showt...t=sliding+door
