PZ Spitfire ESC?
Old 01-01-2008, 08:05 AM
boodaghost
Default PZ Spitfire ESC?
I recently had a bad experience with my Spit on it's second flight where the TX & RX decided they weren't on speaking terms mid flight. I bought the plane off of Ebay with an alledged dead ESC/RX. It turned out that not only was the ESC/RX dead, but the TX had issues too.
I've bought a Spektrum DX7 and am slowly converting some of my parkflyers over to AR6100's
I'm needing advice one what the amperage of the ESC would be recommended for a 480 brushed motor & using Nimh batts if it matters. I don't have the time to do a brushless upgrade so that's out of the question.
Any ideas???
boodaghost is offline
Old 01-01-2008, 03:35 PM
herk_1
Trash Hauler emeritus
herk_1's Avatar
boodaghost - I reported the results of my motor runup tests on a wattmeter with a PZ Spit here (stock brushed 480 motor), if that helps.
herk_1 is offline
Old 01-09-2008, 02:29 AM
fezz
Spit Junkie
fezz's Avatar
i've pulled all the stock electronics from mine too and am using a DX7.
I'm using an Avionics Pilot 35 ESC, but I suspect you can go down to a 25, no problem.
fezz is offline
Old 01-09-2008, 03:15 AM
boodaghost
I ended up buying a Parkflyers 50amp ESC because the Begin Air I have has a 480 in it and I felt with the Spit having a 480 as well, I coudn't go wrong.
thehaze
Warbird Electrics
05-09-2008 04:58 AM
mikidymac
Warbird Electrics
01-10-2008 11:15 PM
Larry G
Warbird Electrics
11-29-2007 02:47 AM
RandolphNav
04-07-2007 05:35 AM
RandolphNav
Warbird Electrics
03-26-2007 01:10 PM
Quick Reply: PZ Spitfire ESC?
Page generated in 0.11330 seconds with 13 queries
