Informal Clubs Club Talk
The Unofficial Central Delaware Parkflyers Association
Old 06-25-2014, 12:42 AM
  #9351
02TAC
Originally Posted by newjak View Post
I have two helis on the bench right now. I decided not to upgrade the 600. I'm going to use the last belt I have. It has flown so great on the belt system. When this belt wears out I'll upgrade to TT. The 450 pro is in for umbrella gear replacement. Should be ready to fly for the weekend.
What is umbrella gear?
02TAC is offline
Old 06-25-2014, 12:48 AM
  #9352
newjak
AMA Park Pilot Partner
newjak's Avatar
Its for the torque tube tail drive system.
http://www.valuehobby.com/helicopter...l45055-01.html
newjak is offline
Old 06-25-2014, 01:02 AM
  #9353
02TAC
OK, never knew they were called umbrella gear. Thanks.
02TAC is offline
Old 06-25-2014, 01:34 AM
  #9354
newjak
newjak's Avatar
Align calls them tail drive gears, but they somehow started being referred to as umbrella gears.
newjak is offline
Old 06-25-2014, 02:57 AM
  #9355
pmikeyg
pmikeyg's Avatar
Newjak...any spare 450 blade shims and tail blades laying around?
pmikeyg is offline
Old 06-25-2014, 03:19 AM
  #9356
newjak
newjak's Avatar
I will look in my parts bin for the shims. I only have plastic tail blades. I have a set of KBDB's in neon yellow. No carbon fiber.
newjak is offline
Old 06-25-2014, 03:41 PM
  #9357
pmikeyg
pmikeyg's Avatar
I'm gonna order some stuff on Friday. I tore my blades up the other day...
pmikeyg is offline
Old 06-25-2014, 06:45 PM
  #9358
newjak
newjak's Avatar
Ohhhh nooooooooo!!! I have an itchy trigger finger....again!
http://www3.towerhobbies.com/cgi-bin...&I=LXZGX7&P=ML
newjak is offline
Old 06-26-2014, 04:14 PM
  #9359
02TAC
RC Car racing, anyone want to go down and check it out?
http://www.clubmiltonspeedway.com/
02TAC is offline
Old 06-26-2014, 06:07 PM
  #9360
pmikeyg
pmikeyg's Avatar
Stinger II airframe and servos...$100
Twist 60 airframe...$60
OMP Yak 60-90 size profille NIB...$100
pmikeyg is offline
Old 06-27-2014, 04:32 AM
  #9361
newjak
newjak's Avatar
Which version is the Yak? Color scheme?
newjak is offline
Old 06-27-2014, 06:50 AM
  #9362
pmikeyg
pmikeyg's Avatar
OMP Razor Yak
White with red/black
pmikeyg is offline
Old 06-28-2014, 10:04 PM
  #9363
newjak
newjak's Avatar
Originally Posted by pmikeyg View Post
OMP Razor Yak
OK. If it was green/black I would be all over it. Maybe I will check it out anyway later in the week.
I'm getting ready for tomorrow's flight session. I am almost finished with the repairs to the Mini Pulse.
newjak is offline
Old 06-29-2014, 02:25 AM
  #9364
pmikeyg
pmikeyg's Avatar
I may chrge up the battery in my profile and bring the Saito 72 back to life!
pmikeyg is offline
Old 06-29-2014, 03:20 PM
  #9365
newjak
newjak's Avatar
Loading up my planes now. See you guys out at the field.
newjak is offline
Old 06-29-2014, 06:31 PM
  #9366
SmoothCruizer
-aggressive flyer-
info from the wise, if any is interested in purchasing a DX9 or more advanced radio, maybe Newjak has better luck BUT....
the supplied SD card is RUBBISH! even horizon/spektrum is aware! and continue to sell these decent radio with a junky card installed, and mine came with version 1.01A.
short story I was updated it and shows signs of WTF and hangs on the main screen ... I used a card from my old cellphone and success without bricking it , now the splash screen turns off and beeps correctly, HAPPY! and leaving the fuk thing alone
SmoothCruizer is offline
Old 06-29-2014, 10:34 PM
  #9367
newjak
newjak's Avatar
I didn't use the supplied SD card. I used my old one from the DX8. I thought I could import my model info but it isn't compatible. What version did you upgrade to? The latest version is 1.06
newjak is offline
Old 06-30-2014, 12:23 AM
  #9368
SmoothCruizer
-aggressive flyer-
yes 1.06... works great
Spektrum™ DX9 AirWare™ Change Log
2014-May-21
Version 1.06
Changes since 2014-April-18
New Features & Improvements
• Added AS3X Gain monitor functions for use with AR636, AR6335, and similar
AS3X receivers. When you enable telemetry option AS3X, you are able to see
gain status in real time, and adjust it with a trimmer. Note that this function
performs the following re-configurations in your radio:
o The F-Mode switch has its outputs set to the proper values for AS3X
operation. If you are using it for other purposes, you will need to
reconfigure those features to allow AS3X to use them.
o Mix 16 (DX10t and higher) is used to control AS3X gain.
o The selected channel is reconfigured for proper control. If you change the
channel, you will need to manually re-assign the old channel to its desired
purpose.
o Enables a screen “AS3X Gains” on the Function List to configure
parameters.
o Enables the AS3X telemetry gain monitor on the telemetry screens.
o If you are using a DX6, you can tweak the gains using the roller while on
the AS3X Gains configuration screen. If you are using a higher radio, you
can adjust at any time using the desired trimmer.
Corrections
• In Heli mode, Governor Trim function now works properly.
• Fixed Servo Travel problem for second Elevator in a 4-Servo swash heli.
• Improved translations in multiple languages
• When using a trimmer in 2- or 3-position mode, trimmers were acting as Flight
Mode trims. They are now operating in Common Mode
• Trim decrement tone was being controlled by the Switch Sounds setting
• Governor Trim on Heli Trim Setup screen is now properly adjustable
• If a radio is configured as a Wireless Trainer Master, if it were used as a wired
slave it would not function. This has been corrected.
Audio System Changes
• No change
Old 06-30-2014, 01:18 AM
  #9369
SmoothCruizer
-aggressive flyer-
Old 06-30-2014, 03:20 AM
  #9370
beyondthebluerc
beyondthebluerc's Avatar
Nice flying with you guys today. Here is the link to the video of your T-Rex 550 Barry http://youtu.be/fPQBHVVmK38
Here are two more links to the Mikado Logo and E-Flite Eratix......
http://youtu.be/CoofU5Hljoo
http://youtu.be/d2RkKFyLyw8
beyondthebluerc is offline
Old 06-30-2014, 05:18 AM
  #9371
newjak
newjak's Avatar
Thanks for posting the videos. I'm glad I waited to bring out the helis this year. I'm having more fun than ever!
newjak is offline
Old 06-30-2014, 05:20 AM
  #9372
newjak
newjak's Avatar
Originally Posted by SmoothCruizer View Post
I haven't upgraded my firmware on the DX9 yet. It looks like it mostly applies to AS3X stuff.
newjak is offline
Old 06-30-2014, 07:19 AM
  #9373
beyondthebluerc
No problem Glad you are having fun with your helis and looking forward to flying with you guys again
Old 06-30-2014, 11:36 PM
  #9374
SmoothCruizer
-aggressive flyer-
Default it happens...
[media]http://www.youtube.com/watch?v=XT7FGQls0KM[/media]
Old 07-01-2014, 04:50 AM
  #9375
beyondthebluerc
Wow classic
Quick Reply: The Unofficial Central Delaware Parkflyers Association
Page generated in 0.20468 seconds with 13 queries
