Power setup for Turmoil
Old 12-16-2005, 03:28 PM
RCBobby
Default Power setup for Turmoil
I am currently finishing a Turmoil 3-D flyer. I plan to use a BM2410-12Y outrunner motor from Quietflight with Li-poly batteries. Is this big enough and is it more powerful than the motor that comes with the kit?
RCBobby is offline
Old 12-16-2005, 04:08 PM
Matt Kirsch
Matt Kirsch's Avatar
Is there a website for this motor? I can't find it on google.
Without the motor's specs, there's no way to tell whether it's the right motor or not. How did you come to choose this motor? That may give us a clue. If you got the idea from someone who is using the same motor in a similar plane, then there's a good chance it'll work. If you just picked it at random, then odds are there will be a problem...
Also, what LiPoly battery are you using, and what prop?
Matt Kirsch is offline
Old 12-16-2005, 04:13 PM
Matt Kirsch
Okay, I found it at xushobby.com.
Yeah, that's got plenty of capacity. Couple it with a 3S LiPoly and a 10x4.7 or 11x4.7 prop, and it'll 3D. The 3S LiPoly must be capable of handling 10 Amps, so something like the 15C Kokam 640 or the ThunderPower 830 would be good choices.
Old 12-16-2005, 04:16 PM
RCBobby
Matt,
I found the motor at a swap meet. The guy assured me that it was bigger and better than my stock motor. There is one born every minute. I have the specs at home. I will look them up later and post them later. Thanks a bunch.
RCBobby is offline
Old 12-17-2005, 12:27 AM
RCBobby
I found the specs. on the motor. Prop -1147, Volts -11.1,Amps.10.9A Thrust-602 Grams KV970 Max Power 160W and thanks for the info on the battery pack.
RCBobby is offline
Old 12-18-2005, 03:22 AM
Matt Kirsch
Yep, that configuration is plenty of power for the ~11oz Turmoil.
Eganwp
3D Flying
02-01-2009 07:32 PM
celticflyer
Foamies
10-04-2008 03:30 PM
Dorsal
08-13-2007 02:20 AM
Nathan
3D Flying
10-02-2006 07:01 PM
rtn9105
3D Flying
8
11-24-2005 02:30 AM
Quick Reply: Power setup for Turmoil
Page generated in 0.11503 seconds with 12 queries
