Charging Question
Old 12-23-2005, 04:54 PM
hemmelou
JUST FLYING
Default Charging Question
What is the best / max current rate that I can set my fast charger to for charging a Electrifly 8 cell 9.6 volts 4/5SC 2000mAh NiMH. I currently set it at 1.0 A and it takes an hour or more.
hemmelou is offline
Old 12-23-2005, 05:10 PM
At 1amp it will take 2+ hours to charge that pack.
You are very safe at 2amps (1c) and that is where I charge most NiMh cells. In a rush at the field I do 2c on most larger cells (like yours). That should charge them in 30 minutes.
If your charger supports and "auto" charge function you can try that and see if it will go faster at the first part of the charge, they typically ramp down after that.
Old 12-23-2005, 08:39 PM
Jim McPherson
Yep, I'd have no problem charging that pack at 2C. I'd probably keep it at 1C when I'm at home just to be easy on the cells.
-Jim
Jim McPherson is offline
Old 12-23-2005, 09:12 PM
hemmelou
JUST FLYING
Default 2 amps = 1 C
Not to sound to stupid but what does a "C" stand for?
hemmelou is offline
Old 12-23-2005, 09:32 PM
C = capacity
So if you have a 1000 mAh pack 1c (one times capacity) is 1000 mAh or 1 amp.
Old 12-24-2005, 07:42 PM
rcnerd
eats lipo for breakfast!
rcnerd's Avatar
C is for "cookie"!!!
rcnerd is offline
Old 12-24-2005, 07:49 PM
And yes C is for cookie as well.
But please don't eat your batteries they look good but taste funny.
Old 12-24-2005, 11:15 PM
rcnerd
rcnerd's Avatar
I beg to differ...check out my title!8D
rcnerd is offline
rednote
11-08-2007 04:40 PM
Micro_R/c.co.za
10
10-18-2007 10:55 AM
Larry G
09-03-2007 04:35 AM
BD Flyer
14
08-05-2007 04:01 AM
pairadocs
11-23-2006 05:23 PM
Quick Reply: Charging Question
Page generated in 0.12775 seconds with 13 queries
