spektrum 6100 question
Will the 6100 be fine for a minifuntana? Would that plane would be considered a parkflyer? 42" wingspan. I wasn't sure or not if I would need the full range reciever for that one or not seems like it is kinda between a full size and park flyer.
I have four of these so-called park flyer receivers. I take care not to mount them alongside any bulky item like a battery or big speed controller that could potentially block out a signal. I have no range problems at all and have had an EasyStar logged at 800 ft altitude. See the attached log. At that height there is not a lot of pleasure in flying a relatively small model. Do you really want a Park Flyer, or any model other than a thermal soarer, further away than that? As long as I can mount these receivers as I have described, I will use them in just about any model. I have such confidence that I have removed a 6200 from my Funjet and replaced it with a 6100. There will be no second chances if a Funjet ever goes out of range, but that is the confidence that I have in the receiver. As an aside, the AR500 5 channel receiver costs the same as the 6100 in the uk, but it is sold as a full range receiver. If you have the choice available, why not give the AR500 a try.
Ken from the UK
Ken from the UK
psychorevo
25
05-21-2008 08:37 PM
sizzler3
01-26-2007 05:32 AM
