Please let me know if this setup looks ok!
Just bought a Hyperion Super Chipmunk with a 64" wingspan that has a flying weight of 6.2 - 6.6 lbs. More info here. [media]http://www.allerc.com/Pictures/CHIP-70-BoxLabel.jpg[/media] I'm considering the following motors:
Turnigy 50-55b (600kv) which claims to be the equivalent of the Axi 4120-14. Link here http://www.hobbyking.com/hobbycity/s...idProduct=4907
Prop will be a 14X9 as suggested by the motor mfg.
For the esc I'm looking at Turnigy Plush 60a with a switch mode BEC seen here. http://www.hobbyking.com/hobbycity/s...idproduct=2166
For the battery, I'm looking at a ZIPPY Flightmax 5000mAh 5S1P 20C seen here. http://www.hobbyking.com/hobbycity/s...00mAh_5S1P_20C_
My two questoins are, will this give me sufficient power to fly the plane if I fly sport aerobatic with the occasional vertical climb to the moon and can that ESC handle the power without bursting into flames?
Thanks for any input, this is my 1st large plane. Doug
You are ok on power, just be sure to either use a separate BEC or carry an onboard flight battery apart from the motor power lipo.
Yes that ESC will handle the power that the motor can take, and what your batteries will deliver, just don't use the BEC from the speed controller.
Thanks Nitro Blast. So even with a "switch mode" ESC I still need a separate BEC?
If so, is there an easy way to explain to me how to install a separate BEC? I've seen information but just don't understand how to do it.:o
Yup, pretty much anytime you run more than 3 cells you want a separate BEC.
If its a big plane, or if I need extra 'umph' from my servos (like retracts on a 60 size airplane) my preference is to run a battery pack.
If you are running a separate BEC, simply wire it up to the same plug that the speed controller is wired to. Both devices on the same male plug, so when you plug the pack in, you energize both.
The advice not to use the internal BEC over 3S only applies to the older linear style BECs and not many modern ESCs still use those.
Yep I love switch mode BEC's in ESC's. No need for an external BEC. Saves a step!
I am waiting on the all new Castle Creations ICE 50amp ESC with a built in switch mode BEC. The ESC is safe to 8s and it will still provide 5amps of power to the airborne system!
Can't wait to get it.......
http://www.hobbyking.com/hobbycity/s..._(DE_Warehouse)
Spec.
TR50-55B
Working Voltage: 8~30
Kv: 600
Weight: 300g
Shaft: 8mm
Dimensions: Length: 55mm
Thrust: 2200 ~ 4600g
Stator Size (AXi Measurement): 40-20
Recomended ESC: 80A ************************************************** **************************************************
Suggested Prop: 5cell:14x9 / 6cell: 14x8
Shaft: 8mm
Power equivalent : .40 to .60 glow engine
Get the 80 amp, you want to have a little reserve, and you never want to be under rated when it comes to ESC, its best to always have a ESC thats 20% more than what the motor calls for, in this case a 100AMP ESC will give you a comfortable reserve, a 80 amp is marginal and will do the job, the bigger the ESC the cooler it will run, hope that helps, Chellie
http://www.castlecreations.com/products/cc_bec.html
Receivers have a common power bus - so if you don't have a battery port - you can plug the BEC into any unused channel.
If you have a 4 Channel receiver, then you will need a y connector, if you have a 6 channel Receiver or more, then just plug into the batt port, or any open port, you need to cut or remove the red wire on the ESC to Receiver connector, if you have a 4 channel receiver, plug the esc to receiver connector in the y connector, with the red wire removed from the esc, plug the UBEC into the y connector other socket, then plug into the throttle port, Hope that helps, Chellie
